FMOD ChannelGroup getNumChannels always 0
Hi guys, my goal is to create an Audio Visualizer and the music have several tracks.I want to add a DSP to every track.
When i call:
int channelNumber = 0;
RuntimeManager.CoreSystem.getChannelsPlaying(out channelNumber);
the channelNumber is absolutely correct.but when i call:
ChannelGroup channelGroup;
RuntimeManager.CoreSystem.getMasterChannelGroup(out channelGroup);
channelGroup.getNumChannels(out channelNumber);
the channelNumber is 0.How can i get each channel to add a DSP?
Each of the FMOD functions will return an FMOD.RESULT which may help you find the cause.
Thanks!!That helps a lot!
