Hey everyone
I’m trying to mod a couple of games running the legacy versions of FMOD Designer 4.28.06 and FMOD Designer 4.44.64 respectively
I’ve recently found myself in need of the command line version of FMOD Designer mentioned in the manual to craft a modding tool, but alas I couldn’t find the program anywhere.
I was wondering if there was still a way to access said software at this time.
Hi @Andrew, could you please give me access to the final version of fmodex/designer?
I have some legacy projects to which I need to add 64-bit support on android, but the version I’m using (4.44.26) is 32-bit only. I assume that 64-bit support was added at some point to fmodex?
Converting to Studio would be quite a bit of a pain which I’m trying to avoid (one of the projects uses the old music system).
