FMOD I dont hear sound
I am using FMOD on Ubuntu and i think that now the sound must be heared, but I dont hear sound.
SoundEngine.h
#ifndef SOUNDENGINE_H_
#define SOUNDENGINE_H_
#include "FMOD/inc/fmod.hpp" //fmod c++ header
//#include "FMODEX/inc/fmodlinux.h"
class SoundEngine{
public:
	bool initSystem(void);
	void update(void);
private:
	//FMod Stuff
		FMOD_SYSTEM     *system; //handle to FMOD engine
	    FMOD_SOUND      *sound1, *sound2; //sound that will be loaded and played
	    FMOD_CHANNELGROUP *channels;
And SoundEngine.cpp
#include "SoundEngine.h"
#include <iostream>
using namespace std;
FMOD_RESULT result;
bool SoundEngine::initSystem()
    result = FMOD_System_Create(&system);
    unsigned int version;
    cout<<result<<endl;
    result = FMOD_System_Init(system, 1, FMOD_INIT_NORMAL, NULL);
    cout<<result<<endl;
    cout<<"Sonido"<<endl;
    //load sounds
    result = FMOD_System_CreateSound(system, "Media/NMG.mp3", FMOD_CREATESAMPLE, 0, &sound1);
    cout<<result<<endl;
    result = FMOD_System_CreateChannelGroup(system,"canal",&channels);
    cout<<result<<endl;
    result = FMOD_System_PlaySound(system,  sound1,channels, 1, NULL);
    cout<<result<<endl;
    return true;
I think that its correct and must play sound, but I dont hear nothing( and I have the computer volume turn on and works). Its there any other method that I need to use?
I also use FMOD_System_Update() in every frame.
And tried to put
while(true) FMOD_System_Update();
Inside the initSystem methor but it doesnt work.
PS: I dont know if this is the correct forum to put this (FMOD 4) but tell me if I am wrong.
EDIT: Moved to FMOD5 category.
You’re passing 1 in fourth argument of FMOD_System_PlaySound, which is means the channel is created in the paused state.
Either you need to pass 0 for that parameter, or get the channel handle back from FMOD_System_PlaySound and call FMOD_Channel_SetPaused(channel, 0).
