Fmod not playing an mpeg stream
Issue:
https://streams.1radio.ca/just is not being played, fmod complains about unsupported format, but according to VLC this is an MPEG Audio Layer 1/2.
Tested on:
Fmod engine 2.02.06, 2.02.03 and 2.01.07, reproduces on all three.
Logs
[LOG] SystemI::init : Initialize version=20203 (120077), maxchannels=32, flags=0x00100004
[LOG] SystemI::setOutputInternal : Setting output to ‘FMOD WASAPI Output’
[LOG] OutputWASAPI::init : Mix Format (WAVEFORMATEX): wFormatTag=0xFFFE, nChannels=2, nSamplesPerSec=48000, nAvgBytesPerSec=384000, nBlockAlign=8, wBitsPerSample=32, cbSize=22.
[LOG] OutputWASAPI::init : Mix Format (WAVEFORMATEXTENSIBLE): wValidBitsPerSample=32, dwChannelMask=0x00000003, SubFormat=00000003-0000-0010-8000-00AA00389B71.
[LOG] OutputWASAPI::init : Output buffer size: 4096 samples, latency: 0.00ms, period: 10.00ms, DSP buffer: 1024 * 4
[LOG] Thread::initThread : Init FMOD stream thread. Affinity: 0x4000000000000003, Priority: 0xFFFF7FFB, Stack Size: 98304, Semaphore: No, Sleep Time: 10, Looping: Yes.
[LOG] Thread::initThread : Init FMOD mixer thread. Affinity: 0x4000000000000001, Priority: 0xFFFF7FFA, Stack Size: 81920, Semaphore: No, Sleep Time: 0, Looping: Yes.
[LOG] SystemI::createSound : filename = https://streams.1radio.ca/just : mode 02010088
[LOG] SystemI::createSound : FMOD_NONBLOCKING specified. Putting into queue to be opened asynchronously!
[LOG] Thread::initThread : Init FMOD nonblocking thread (0). Affinity: 0x4000000000000003, Priority: 0xFFFF7FFC, Stack Size: 114688, Semaphore: Yes, Sleep Time: 0, Looping: Yes.
[LOG] SystemI::createSound : setdata soundi = 0000022B8CBB27A8 : node = 0000022B8ADE7580
[LOG] SystemI::createSound : add node to async list : head = 0000022B8597DEF8. list count = 0
[LOG] AsyncThread::threadFunc : Starting Asynchronous operation on sound 0000022B8CBB27A8
[LOG] SystemI::createSoundInternal : Create name=‘https://streams.1radio.ca/just’, mode=0x02010088
[LOG] FMOD_OS_Net_Connect : Attempting connection to ‘159.203.7.159:80’
[ERR] CodecOggVorbis::openInternal : failed to open as ogg
[ERR] CodecMIDI::openInternal : ‘HThd’ ID check failed [<!DO]
[LOG] AsyncThread::threadFunc : Finished Asynchronous operation on sound 0000022B8CBB27A8
[WRN] OutputWASAPI::mixerThread : Starvation detected in WASAPI output buffer!
This url is redirecting to a webpage instead of providing a valid audio stream, hence the “<!DO” when trying to read the first chunk of data but getting “<!DOCTYPE HTML>”. The Ogg and MIDI errors are just a result of the fallback behaviour of trial and error attempts at finding the correct format.
The reason for the redirect is because we do not currently support https. There is a task to implement https/SSL support for net streams in a future release.
Thank you for the info.
