FMOD Studio Oculus not compatable with UE4.7.2?
I have just downloaded the Fmod plugin for UE4, Dropped the “FMODStudio” folder into my Unreal Engine/4.7/Engine/Plugins folder but when I attempt to run UE4 it loads up to about 70% and fails to load and says “the module ‘FMODStudioOculus’ does not appear to be compatible with the current version of the engine. The plugin may need to be recompiled”. I assume I’m doing something wrong or missing something here because the downloads page says its for UE4 4.6 , 4.7 & 4.8…
Any help or suggestions would be greatly appreciated.
Thanks.
We switched over to 4.8 for the latest release. We only build the binaries against one version of the engine. To use the plugin for a different version, the best bet will be to get the source from github and follow one of the steps described in the following post:
http://52.88.2.202/questions/question/how-to-build-fmodstudiooculus-plugin-ue4-windows
Thanks that solved my problem!, the update to 4.8 was all I needed to do. thankfully I didn’t need to re-build and scrips.
