FMOD turn off
Every 20 minutes, aprox, FMOD Studio crushes. Someone know the reason?
Process: fmodstudio [971]
Path: /Applications/FMOD Studio.app/Contents/MacOS/fmodstudio
Identifier: org.fmod.fmodstudio
Version: 2.3.12
Code Type: ARM-64 (Native)
Parent Process: launchd [1]
User ID: 501
Date/Time: 2026-06-03 08:32:16.0102 +0200
OS Version: macOS 14.1 (23B2073)
Report Version: 12
Anonymous UUID: 248AFF4C-7BD4-691C-A91D-B4A8106D039B
Time Awake Since Boot: 170 seconds
System Integrity Protection: enabled
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_CRASH (SIGABRT)
Exception Codes: 0x0000000000000000, 0x0000000000000000
Termination Reason: Namespace SIGNAL, Code 6 Abort trap: 6
Terminating Process: fmodstudio [971]
Application Specific Information:
abort() called
Hi! A few questions:
  • Does the crash occur with FMOD Studio versions other than 2.03.12?
  • Are you doing anything similar each time before the crash?
  • Does a crash report dialog appear when the crash occurs? If so, could I get you to link this forum thread in the report box so I can check it in our crash tracker?
  • Can you check ~/Library/Application Support/FMOD Studio for any Studio logs, and upload one that contains the crash?
Hello, there’s not apparent reason for the crash. I’m doing different tasks. By email I annex the crash report so I can not annex that in this forum
