Get parameter ID from EventEmitter
I’m trying to get the parameter ID from a StudioEventEmitter, but there seem to have been some changes to the API, as I’m getting the following error:
“StudioEventEmitter.Event” is obsolete: Use the EventReference field instead"
This is my code:
public FMODUnity.StudioEventEmitter Emitter;
FMOD.Studio.EventDescription OcclusionDescription;
FMOD.Studio.PARAMETER_DESCRIPTION VolumeDescription;
void Awake()
        OcclusionDescription = FMODUnity.RuntimeManager.GetEventDescription(Emitter.Event);
        OcclusionDescription.getParameterDescriptionByName("Volume", out VolumeDescription);
        VolumeId = VolumeDescription.id;
How do I change it, to make it work with the new API?
All you need to change is the line
To
OcclusionDescription = FMODUnity.RuntimeManager.GetEventDescription(Emitter.EventReference);
Thank you very much, works like a charm.
