I’m having some trouble with a simple script.
I’ve got an Fmod event called ‘Ambience’ with a Parameter called ‘Height’ which adds wind sounds to the ambience.
I want the ‘Height’ to relate to the Y axis position of my player in Unity. Can someone pls help me with this script?
I am no programmer, but I’ll give it a try.
Basically what you need to do is to get the height value of your player from the Y position of the Transform component on your Player GameObject. Then you should pass that value to the “Height” parameter in your FMOD event.
Here’s how I would do it:
using System.Collections;
using UnityEngine;
public class YourScript : MonoBehaviour
public Transform myTransform;
void Start()
myTransform = GetComponent<Transform>();
void FixedUpdate()
//you can probably do this in Update() as well
float playerHeight = myTransform.position.y;
//check the value on the console
Debug.Log(playerHeight);
//apply the value to FMOD parameter
var emitter = GetComponent<FMODUnity.StudioEventEmitter>();
emitter.SetParameter("Height", playerHeight);
Maybe there’s a more efficient way to do it, but it should work.
