i saw all h5 examples, created by preload asset via prerun, but i want to create sound with path not preload.how can i do?
Which examples are you referring to?
There are a few methods by which you can load data to make sounds explained under FMOD API | Platform Details HTML5.
thanks for your answer. I saw examples of fmod h5 engine.I hope I can create with path. not load in prerun
and Now, I met another problem in h5. In my project, sometimes, it was doing large logics and made a little lag, at that time, the voice was shaked. how can i solve this problem?
When referring to the path, are we talking about a file on the user’s computer or an event path?
Would it be possible to elaborate on the logic that may be causing the lag? If not, could you upload a copy of your project to your profile for me to test?
