JS Scripting API: checking if event has a multi-instrument
I’m writing a script with JS and writing a function that returns true if an event has a multi instrument on any parameter sheet. This is my current code:
function HasVariations( event )
	var eventSheets = event.parameters;
	eventSheets.push( event.timeline );
	console.log("EVENT SHEETS: " + eventSheets );
	for( var i = 0; i < eventSheets.length; i++ )
		var instruments = eventSheets[ i ].modules;
		console.log("INSTRUMENTS IN SHEET: " + instruments );
		for( var j = 0; j < instruments.length; j++ )
			if (instruments[ j ].entity === "MultiSound" )
				return true;
	return false;
If my eventSheets variable only includes a timeline, this works fine. But if I’m iterating over an action sheet or other parameter sheet then I get the following error:
TypeError: Result of expression 'instruments[ j ]' [undefined] is not an object., callstack:HasVariations(event = (ManagedObject:Event))
How could I make this code work when iterating over both timelines and param sheets?
Thanks in advance!
EDIT: actually the error only seems to happen when iterating over an Action Sheet - timelines and other parameter sheets work fine
Same error happens when I try to dump() information from a module/instrument that lives in an action sheet vs a timeline/param sheet
Ok found a solution in this forum thread: How can I get sheet content by javascript? - #4 by MisakaCirno
TL;DR: Action sheets are actually multi instruments so instead of eventSheets[ i ].modules it had to be eventSheets[ i ].modules.sounds for action sheets.
Function ended up looking like this:
		var instruments = [];
		if( eventSheets[ i ].isOfExactType('ActionSheet'))
			instruments = eventSheets[ i ].modules.sounds;
		else
			if (instruments[ j ].entity == "MultiSound" )
				return true;
	return false;
Thank you for sharing the solution here!
