Hello there!
I’m having a question regarding monitoring of 7.1.4 channels output.
Simply put - if I have a sound card that has 12 analog outputs, will I be able to monitor that properly in fmod?
From what I’ve reasearched allready - fmod will only go as high as system output is set (and windows doesn’t seem to go higher than 7.1 discrete) and it seems the only way to go is via dolby access app over hdmi to decoder. Is that correct and it’s the only option to do so?
Cheers,
Marcin
