I’m using FMOD to play an event, the event has multiple parameters and a sound for every event.
When playing from code, the initial value always plays along with the correct value selected by the parameter, the initial value sound is a long loop which is why it’s so noticeable.
This is the code that sets the parameters, it’s called once, parameters are correct, all the set-calls returns “OK” results.
private void PlayLooping(Source source, List<(string, string)> parameters)
StopLooping(source);
if (sources[source] == null)
return;
EventInstance instance = RuntimeManager.CreateInstance(master);
RuntimeManager.AttachInstanceToGameObject(instance, sources[source].transform);
if (instances.ContainsKey(source))
instances[source] = instance;
else
instances.Add(source, instance);
for (int i = 0; i < parameters.Count; i++)
FMOD.RESULT result = instance.setParameterByNameWithLabel(parameters[i].Item1, parameters[i].Item2);
Debug.Log($"{parameters[i].Item1} set to {parameters[i].Item2}, result: {result}");
Debug.Log($"Playing: {source}");
instance.start();
This is my event setup.
What happens is that the idle-loop ALWAYS play, regardless if the parameters is set before/after start, or if the parameters change.
The correct sound also plays.
Setting the parameter initial value to an empty slot, such as “Death” or “Hurt” stops the Idle-loop from playing.
What am I doing wrong?
Can I please grab your integration version?
Can you please try starting the instance before setting the parameter:
return;
instance.start();
else
The issue may be that the instance is not valid yet which is confusing why it is returning FMOD_OK. You can confirm that an instance is valid with instance.isValid().
Hope this helps.
Thank you for the rapid response!
Our integration version is 2.02.20, running in Unity 2022.3.25f1.
All instances are valid, changing parameters to be set before/after starting an event does not change anything at all.
If it helps, some context: We are setting up a system where animation event can trigger audio events, with parameters specified by the animation event string parameter, if that changes anything.
Having an empty initial value is a work-around, but it’s very odd the issue happens.
Thank you for sharing the workaround.
I have set up a simple test:
Unfortunately, I cannot reproduce the issue. It is playing
Value B without issue.
Would it be possible to try a simple reproduction of the issue and let me know if it continues?
