An option may be rather than using the Emitter instance, if you create the instance yourself:
private FMOD.Studio.EventInstance inst;
void Start()
inst = FMODUnity.RuntimeManager.CreateInstance("event:/Sound/" + d.moveSOund);
if (!inst.isValid())
Debug.Log("Inst is not valid yet");
else
Debug.Log("Inst is valid right after creating it");
FMOD.RESULT result = inst.setParameterByName("Fraction", (int)d.fraction, false);
if (result != FMOD.RESULT.OK)
Debug.Log($"Failed to set param with result {result}");
else
Debug.Log("Successfully set the parameter without playing the event");
Unfortunately, as the emitter does not create the instance till it is about to be played it will not be valid for the parameter to be set.
Do I need to free/destroy the EventInstance when the gameobject is destroyed?
Yes, you can call inst.release() right after it is started so that when the event stops it is cleaned up automatically. More info can be found here: FMOD Engine | Studio API Reference - Studio::EventInstance
haha I’m actually curious on how emitter’s “Initial Parameter Values” works in the inspector.
Ah sorry for the confusion.
In the StudioEventEmitter.cs script in the PlayInstance() function, after the instance is created it will loop through a list of Params like we were doing when creating the instance our self:
foreach (var param in Params) // Line 297
instance.setParameterByID(param.ID, param.Value);
