Hello, im having an issue with transition regions. I have setup a parameter that switches to region “Danger” when the value is set to 1, and switches to “Nodanger” once the value hits 2. The first transition works perfectly fine, but whenever i switch the value to 2, my playhead jumps to the start of “Nodanger” and freezes. I have also notice a vertical line in my transition conditions box. Don’t know if it has anything to the with the issue, but worth mentioning.
Are the conditions of the “To Danger” transition region still met?
The line indicates the current value of the parameter used by that parameter condition. In your screenshot, it indicates that the ‘Danger’ parameter’s value is zero.
