hi~I’ve got the way to add a scripting action item to fmod menu,but I want to add some action to select event. The most convenient way to do that is to add a action item to right-click contextmenu. Did fmod has the way to do that?
Unfortunately menu items can only be added to the Scripts menu at the moment. I have raised this with the Dev team for consideration in a future release. Thank you for the suggestion!
In the meantime perhaps you could assign a keySequence to your menu item to execute your script without needing to navigate the Scripts menu?
ok~thanks
