Separate asset and meta in banks
Hi, do I need to tell unity that I’m splitting the banks in metadata and assets?
Where?
I tried to change it in fmod but unity seems not to see the banks anymore.
thanks
No, you don’t need to tell Unity that you’re splitting your assets and metadata. FMOD for Unity should detect all banks in the directory selected under FMOD Settings → Bank Import. If you choose to load “all” banks under FMOD Settings → Initialization → Load Banks, FMOD for Unity will load all banks it detects, including split banks. If you select “Specified” instead, you should be able to select your split banks.
If this isn’t the behaviour you’re describing, can I get your FMOD for Unity plugin and FMOD Studio versions?
