SERIOUS bug with labeled parameters and magnets
Hi, I’ve encountered this bizzare bug that makes it so a magnet region triggers when skipping more than 3 states of a parameter.
Here’s my parameter setup:
And here is a video demonstrating the issue (notice the “Chase” magnet region get triggered when skipping multiple parameter states)
As you can see, when skipping multiple states some magnet regions get triggered very briefly. This is especially noticable when using transitions between regions because of the fade-in.
I’m using FMOD v2.02.28
That certainly is unexpected behavior. unfortunately, I haven’t been able to reproduce it here, which means I must be doing something differently to you.
Could you please click on your parameter’s name in the transport bar so that its properties are displayed in the deck, and post a screenshot of what you find here? There might be a clue there as to what’s causing this.
