SetEvent clearing automatedparametercache
We recently upgraded our project from Unreal 5.5.4 to 5.7 alongside upgrading FMOD Unreal integration from 2.03.11 to 2.03.14.
In our project we use SetEvent calls on the FMODAudioComponent to change between events we want to play. After upgrading this method became broken. I have it locally fixed but perhaps there is more wrong or something I misunderstand?
SetEvent clears the newly added AutomatedParameterCache but does not repopulate causing the occlusion to break on PlayInternal. That said
adding a call CacheDefaultParameterValues() after the event is updated is not sufficient as GetParameterDescriptions is set for Editor
and returns a nullptr in a non-editor build. I changed this to FMOD::Studio::EventDescription *EventDesc = IFMODStudioModule::Get().GetEventDescription(this, EFMODSystemContext::Max);
Thank you
Thanks for reporting this, we have an upcoming fix for the EFMODSystemContext in UFMODEvent::GetParameterDescriptions. I have added another task to cache the parameters of the new event being set.
