EDIT 1
Added debug.log for fmodEventInstance.start()
/EDIT 1
I am trying to get a basic step sound to play but when I go into “play mode” all I hear is a static sound for half a second and silence.
This is all the code related to FMOD.
using UnityEngine;
using System.Collections;
using System.Xml;
using FMOD.Studio;
public class Movement : MonoBehaviour {
	private	FMOD_StudioSystem 					system;
	private FMOD.Studio.EventInstance			fmodEventInstance;
	public  FMOD.Studio.Bank					fmodBank;
	private FMOD.Studio.ParameterInstance		fmodParaInst;
	bool playing = false;
	void Start() {
		//fmodStudioSystem.GetEvent();
		//fmodEmitter = GetComponent<FMOD_StudioEventEmitter>();
		anim = GetComponent<Animator>();
		nav = GetComponent<NavMeshAgent>();
        nav.updateRotation = false;
		//Debug.Log(system.GetEvent("Debug.Log(system.GetEvent(""));"));
		system = FMOD_StudioSystem.instance;
		string fileName = Application.dataPath + "/StreamingAssets/Master Bank.bank";
		system.System.loadBankFile(fileName,LOAD_BANK_FLAGS.NORMAL , out fmodBank);
		FMOD.Studio.Bank bankStrings;
		system.System.loadBankFile(fileName + ".strings",LOAD_BANK_FLAGS.NORMAL, out bankStrings);
		fmodEventInstance = system.GetEvent("event:/Steps");
		fmodEventInstance.getParameter("Steps", out fmodParaInst);
		Debug.Log("StudioSystem      -> " + system 				+ " <-");
		Debug.Log("Bank              -> " + fmodBank 			+ " <-");
		Debug.Log("EventInstance     -> " + fmodEventInstance 	+ " <-");
		Debug.Log("ParameterInstance -> " + fmodParaInst 		+ " <-");
		Debug.Log("Start             -> " fmodEventInstance.start()+ " <-");
Debug.Log output[code]
StudioSystem      ->FMOD_StudioSystem (FMOD_StudioSystem) <-
UnityEngine.Debug:Log(Object)
Movement:Start() (at Assets/Scripts/Player/Movement.cs:43)
Bank              -> <-
Movement:Start() (at Assets/Scripts/Player/Movement.cs:44)
EventInstance     ->FMOD.Studio.EventInstance <-
Movement:Start() (at Assets/Scripts/Player/Movement.cs:45)
ParameterInstance -> <-
Movement:Start() (at Assets/Scripts/Player/Movement.cs:46)
Start             -> OK <-
Movement:Start() (at Assets/Scripts/Player/Movement.cs:47)
[/code]
Anyone has any idea what I can try?
