In our datalab I noticed that when running the latest installer of Fmod (2.02.04) from command line with the /S toggle it will pop up with a dialogue for reboot. Is there a way to toggle off the Reboot option so I can control when to reboot the machines
It sounds like the VC_redist.x64.exe is being installed and requiring a reboot, which is odd considering the installer is told to not require a reboot. It would likely help if you sourced the latest VC redist file from Microsoft and install it silently before the FMOD Studio installer, which should bypass the need to install it through the FMOD Studio installer.
