I’m creating a sync point on a sound
// add a sync point so we get a callback before the end
unsigned int length = 0;
result = sound->getLength(&length, FMOD_TIMEUNIT_MS);
const char *name = "sound-end";
FMOD_SYNCPOINT *syncpoint;
result = sound->addSyncPoint(length - 1, FMOD_TIMEUNIT_MS, name, &syncpoint);
if (result != FMOD_OK) {
printf("fmod:: Error setting sound sync point because: %s\n", FMOD_ErrorString(result));
then setting a callback for the channel
// set the channelcontrol callback for notifications
result = channel->setCallback(&channelControlCallback);
printf("fmod:: Error setting channel control callback because: %s - %s\n", FMOD_ErrorString(result),
url);
here’s the callback
FMOD_RESULT F_CALLBACK channelControlCallback(FMOD_CHANNELCONTROL *channelcontrol, FMOD_CHANNELCONTROL_TYPE controltype, FMOD_CHANNELCONTROL_CALLBACK_TYPE callbacktype, void *commanddata1, void *commanddata2) {
if (controltype == FMOD_CHANNELCONTROL_CHANNEL && callbacktype == FMOD_CHANNELCONTROL_CALLBACK_END) {
FMOD::Channel *channel = reinterpret_cast<FMOD::Channel *>(channelcontrol);
echoes_sound_data *userdata;
FMOD_RESULT result;
result = channel->getUserData((void **)&userdata);
printf("fmod:: Error getting userdata in callback because: %s\n", FMOD_ErrorString(result));
return FMOD_OK;
if (userdata != nullptr) {
playerDidEnd(userdata->context);
if (controltype == FMOD_CHANNELCONTROL_CHANNEL && callbacktype == FMOD_CHANNELCONTROL_CALLBACK_SYNCPOINT) {
FMOD_RESULT result;
int sync_point_index = *((int *)commanddata1);
return FMOD_OK;
return FMOD_OK;
The sounds plays fine, however, the callback gets called with FMOD_CHANNELCONTROL_CALLBACK_END immediately, but never at the end of the sound. The FMOD_CHANNELCONTROL_CALLBACK_SYNCPOINT never gets called.
I’m sure it’s something obvious I’m missing, but I can’t see it. Any help would be greatly appreciated!
