Hello guys!
After I reformat my PC, I started to get an error msg when I select “Asio” on output device, it says “Unable to initialize the selected device. No sound will be produced. Please select another configuration.”
Before I reformat my PC, everything was fine. It happens even if FMOD is the only one using the interface. What it could be?
I’m using Scarllet 2i2 3rd generation, FMOD 2.01.14, win10
Here is the console’s logging
17:17:52 [Initialize Sound System 0x00000179165fd1e0]: Time started
17:17:52 fmod_output_asio.cpp(212), OutputASIO::enumerate(): IASIO::init failed for driver 0 (Focusrite Thunderbolt ASIO): 'Cannot open Focusrite Thunderbolt ASIO. (Error code: 0x54f)
17:17:52 fmod_output_asio.cpp(223), OutputASIO::enumerate(): CoCreateInstance returned 0x80040154 for driver 2.
17:17:52 fmod_output_asio.cpp(212), OutputASIO::enumerate(): IASIO::init failed for driver 5 (ZOOM H and F Series Async ASIO): 'No device
17:17:52 fmod_output_asio.cpp(348), OutputASIO::init(): IASIO::init failed: 'Cannot open Focusrite Thunderbolt ASIO. (Error code: 0x54f)
