Unity FMOD GVR - Editor crash when playing sound through script
Hello, I have a project in Unity with both FMOD and GoogleVR audio plugins installed. Playing certain sound events through scripts crashes the editor (works fine in build). Any clue what might be causing this ?
Error log below :
0x000007FED336F62B (gvraudio) FMODGetPluginDescriptionList
0x000007FED336E4B8 (gvraudio) FMODGetPluginDescriptionList
0x000007FED336DF5A (gvraudio) FMODGetPluginDescriptionList
0x000007FED336C9E8 (gvraudio) FMODGetPluginDescriptionList
0x000007FED336DF32 (gvraudio) FMODGetPluginDescriptionList
0x000007FED3348148 (gvraudio) FMODGetPluginDescriptionList
0x000007FED3343FE8 (gvraudio) FMODGetPluginDescriptionList
ERROR: SymGetSymFromAddr64, GetLastError: โ€˜Tried accessing non valid addressโ€™ (Address: 000007FED334082E)
0x000007FED334082E (gvraudio)
0x000007FED2D0639D (fmodstudiol) FMOD::ChannelGroup::release
0x000007FED2D044C1 (fmodstudiol) FMOD::ChannelGroup::release
0x000007FED2D44CC6 (fmodstudiol) FMOD::GeometryI::setUserData
0x000007FED2D45226 (fmodstudiol) FMOD::GeometryI::setUserData
0x000007FED2D4501C (fmodstudiol) FMOD::GeometryI::setUserData
0x000007FED2DB5921 (fmodstudiol) FMOD::GeometryI::setUserData
0x000007FED2D18791 (fmodstudiol) FMOD::ChannelI::validate
0x000007FED2CE8217 (fmodstudiol) FMOD::DSP::showConfigDialog
0x000007FED2E01C17 (fmodstudiol) FMOD::GeometryI::setUserData
0x000007FED2E01DBE (fmodstudiol) FMOD::GeometryI::setUserData
0x00000000777259CD (kernel32) BaseThreadInitThunk
0x000000007795A561 (ntdll) RtlUserThreadStart
EDIT : So after 10 or so hours of debugging, it seems sometimes, 3d attributes on some events created from scripts are not initialized, causing a crash. I donโ€™t know what causes some specific events to not be initialized (might be networked objects, donโ€™t really have the time to reproduce the issue) BUT the fix was simple enough in my case. Just initialize the 3d attributes of your event before starting it :
sfxInstance = FMODUnity.RuntimeManager.CreateInstance(eventName);
sfxInstance.set3DAttributes(FMODUnity.RuntimeUtils.To3DAttributes(gameObject, GetComponent<Rigidbody>()));
FMODUnity.RuntimeManager.AttachInstanceToGameObject(sfxInstance, this.transform, this.GetComponent<Rigidbody>());
sfxInstance.start();
Hope this helps.
Iโ€™ve also been having this issue since the recent Unity update. Working with instances in the script has been crashing the editor every time.
I fixed my issue, donโ€™t know if it will fix yours. Answer in original post.
So after 10 or so hours of debugging, it seems sometimes, 3d attributes on some events created from scripts are not initialized, causing a crash. I donโ€™t know what causes some specific events to not be initialized (might be networked objects, donโ€™t really have the time to reproduce the issue) BUT the fix was simple enough in my case. Just initialize the 3d attributes of your event before starting it ; code in original post.
Thank you for providing the solution to your issue Guillaume. Our team is looking into this crash now. Thanks for bringing it to our attention.
Hi Guillaume and Benjamin,
Thanks for letting us know about this.
It appears that sometimes Unity can crash if the position values for the created events are too large. Weโ€™ve fixed this and will be in the next Unity integration release.
Thanks,
Richard
Excuse me. I got an error same this, but Iโ€™m not sure. Please help me check it.
Unity Version: 2018.3.13f1
Fmod Version: fmodstudio20000
Crash!!!
SymInit: Symbol-SearchPath: โ€˜.;D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289;D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289;C:\Windows;C:\Windows\system32;SRVC:\websymbolshttp://msdl.microsoft.com/download/symbols;โ€™, symOptions: 534, UserName: โ€˜Lyanโ€™
OS-Version: 10.0.0
D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289\Basketball.exe:Basketball.exe (00007FF73F850000), size: 667648 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 2018.3.13.21642
C:\Windows\SYSTEM32\ntdll.dll:ntdll.dll (00007FFF972F0000), size: 1970176 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.556
C:\Windows\System32\KERNEL32.DLL:KERNEL32.DLL (00007FFF96A70000), size: 724992 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.706
C:\Windows\System32\KERNELBASE.dll:KERNELBASE.dll (00007FFF93AE0000), size: 2568192 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.556
D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289\UnityPlayer.dll:UnityPlayer.dll (00007FFF51AB0000), size: 23842816 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 2018.3.13.21642
C:\Windows\System32\USER32.dll:USER32.dll (00007FFF96610000), size: 1638400 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.376
C:\Windows\System32\win32u.dll:win32u.dll (00007FFF93DC0000), size: 131072 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\GDI32.dll:GDI32.dll (00007FFF94780000), size: 163840 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.285
C:\Windows\System32\gdi32full.dll:gdi32full.dll (00007FFF93840000), size: 1646592 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.706
C:\Windows\System32\msvcp_win.dll:msvcp_win.dll (00007FFF946E0000), size: 651264 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.619
C:\Windows\System32\ucrtbase.dll:ucrtbase.dll (00007FFF939E0000), size: 1015808 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.677
C:\Windows\System32\ole32.dll:ole32.dll (00007FFF948F0000), size: 1380352 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.407
C:\Windows\System32\combase.dll:combase.dll (00007FFF962E0000), size: 3284992 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.619
C:\Windows\System32\RPCRT4.dll:RPCRT4.dll (00007FFF947B0000), size: 1196032 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.648
C:\Windows\System32\bcryptPrimitives.dll:bcryptPrimitives.dll (00007FFF937C0000), size: 499712 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\sechost.dll:sechost.dll (00007FFF968A0000), size: 372736 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.319
C:\Windows\System32\SHLWAPI.dll:SHLWAPI.dll (00007FFF96840000), size: 331776 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\msvcrt.dll:msvcrt.dll (00007FFF969D0000), size: 647168 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 7.0.17134.1
C:\Windows\SYSTEM32\VERSION.dll:VERSION.dll (00007FFF8ED00000), size: 40960 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\SETUPAPI.dll:SETUPAPI.dll (00007FFF94A50000), size: 4501504 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\cfgmgr32.dll:cfgmgr32.dll (00007FFF93770000), size: 299008 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\ADVAPI32.dll:ADVAPI32.dll (00007FFF97120000), size: 659456 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.471
C:\Windows\System32\SHELL32.dll:SHELL32.dll (00007FFF94EA0000), size: 21233664 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.441
C:\Windows\System32\shcore.dll:shcore.dll (00007FFF96910000), size: 692224 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.112
C:\Windows\System32\windows.storage.dll:windows.storage.dll (00007FFF93DE0000), size: 7393280 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.677
C:\Windows\System32\kernel.appcore.dll:kernel.appcore.dll (00007FFF936A0000), size: 69632 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.112
C:\Windows\System32\profapi.dll:profapi.dll (00007FFF93660000), size: 126976 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\powrprof.dll:powrprof.dll (00007FFF93610000), size: 311296 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\FLTLIB.DLL:FLTLIB.DLL (00007FFF93600000), size: 40960 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\WS2_32.dll:WS2_32.dll (00007FFF96DB0000), size: 442368 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\OLEAUT32.dll:OLEAUT32.dll (00007FFF96CB0000), size: 794624 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.706
C:\Windows\System32\IMM32.dll:IMM32.dll (00007FFF96D80000), size: 184320 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\CRYPT32.dll:CRYPT32.dll (00007FFF944F0000), size: 1974272 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\MSASN1.dll:MSASN1.dll (00007FFF93680000), size: 73728 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\OPENGL32.dll:OPENGL32.dll (00007FFF6A9B0000), size: 1179648 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\WINMM.dll:WINMM.dll (00007FFF91460000), size: 143360 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\bcrypt.dll:bcrypt.dll (00007FFF93140000), size: 151552 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.112
C:\Windows\SYSTEM32\WINHTTP.dll:WINHTTP.dll (00007FFF8EEA0000), size: 905216 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.590
C:\Windows\SYSTEM32\HID.DLL:HID.DLL (00007FFF92340000), size: 49152 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\WindowsCodecs.dll:WindowsCodecs.dll (00007FFF8E800000), size: 1761280 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.345
C:\Windows\SYSTEM32\dwmapi.dll:dwmapi.dll (00007FFF91940000), size: 167936 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\WSOCK32.dll:WSOCK32.dll (00007FFF70C00000), size: 36864 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\GLU32.dll:GLU32.dll (00007FFF6CA90000), size: 180224 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\WINMMBASE.dll:WINMMBASE.dll (00007FFF91430000), size: 172032 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\system32\uxtheme.dll:uxtheme.dll (00007FFF91870000), size: 622592 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289\MonoBleedingEdge\EmbedRuntime\mono-2.0-bdwgc.dll:mono-2.0-bdwgc.dll (00007FFF51340000), size: 7757824 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™
C:\Windows\System32\PSAPI.DLL:PSAPI.DLL (00007FFF96900000), size: 32768 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\MSWSOCK.dll:MSWSOCK.dll (00007FFF92E60000), size: 417792 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\CRYPTBASE.DLL:CRYPTBASE.DLL (00007FFF93010000), size: 45056 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\MSCTF.dll:MSCTF.dll (00007FFF96B30000), size: 1519616 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.619
C:\Windows\SYSTEM32\d3d11.dll:d3d11.dll (00007FFF903A0000), size: 3190784 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.441
C:\Windows\SYSTEM32\dxgi.dll:dxgi.dll (00007FFF923A0000), size: 765952 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.112
C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_da9565e651bdc61f\nvldumdx.dll:nvldumdx.dll (00007FFF8D570000), size: 962560 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 24.21.13.9755
C:\Windows\System32\WINTRUST.DLL:WINTRUST.DLL (00007FFF93D60000), size: 356352 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.556
C:\Windows\System32\imagehlp.dll:imagehlp.dll (00007FFF96EA0000), size: 118784 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\CRYPTSP.dll:CRYPTSP.dll (00007FFF93020000), size: 94208 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\system32\rsaenh.dll:rsaenh.dll (00007FFF92A40000), size: 208896 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.254
C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_da9565e651bdc61f\nvwgf2umx.dll:nvwgf2umx.dll (00007FFF5DCC0000), size: 34197504 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 24.21.13.9755
C:\Windows\system32\nvspcap64.dll:nvspcap64.dll (00007FFF84DC0000), size: 2514944 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 3.13.1.30
C:\Windows\SYSTEM32\ntmarta.dll:ntmarta.dll (00007FFF926D0000), size: 200704 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\clbcatq.dll:clbcatq.dll (00007FFF967A0000), size: 655360 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 2001.12.10941.16384
C:\Windows\system32\wbem\wbemprox.dll:wbemprox.dll (00007FFF80AB0000), size: 69632 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\wbemcomn.dll:wbemcomn.dll (00007FFF822B0000), size: 536576 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\system32\wbem\wbemsvc.dll:wbemsvc.dll (00007FFF804A0000), size: 81920 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\system32\wbem\fastprox.dll:fastprox.dll (00007FFF80540000), size: 991232 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\MMDevApi.dll:MMDevApi.dll (00007FFF8A270000), size: 483328 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\PROPSYS.dll:PROPSYS.dll (00007FFF92010000), size: 1785856 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 7.0.17134.619
C:\Windows\System32\DEVOBJ.dll:DEVOBJ.dll (00007FFF93260000), size: 159744 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\AUDIOSES.DLL:AUDIOSES.DLL (00007FFF708B0000), size: 1228800 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.619
C:\Windows\SYSTEM32\AVRT.dll:AVRT.dll (00007FFF8E770000), size: 40960 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\wintypes.dll:wintypes.dll (00007FFF8EA70000), size: 1363968 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.523
C:\Windows\WinSxS\amd64_microsoft.windows.common-controls_6595b64144ccf1df_6.0.17134.706_none_fb43a2cb30647007\comctl32.dll:comctl32.dll (00007FFF89480000), size: 2527232 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 6.10.17134.706
C:\Windows\SYSTEM32\TextInputFramework.dll:TextInputFramework.dll (00007FFF88A50000), size: 614400 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.376
C:\Windows\SYSTEM32\CoreUIComponents.dll:CoreUIComponents.dll (00007FFF8DFB0000), size: 3268608 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.376
C:\Windows\SYSTEM32\CoreMessaging.dll:CoreMessaging.dll (00007FFF91220000), size: 892928 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.471
C:\Windows\SYSTEM32\xinput9_1_0.dll:xinput9_1_0.dll (00007FFF854C0000), size: 28672 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
D:\Pack\trunk\Build\Client\Basketball a0.1.0 28289\Basketball_Data\Plugins\fmodstudio.dll:fmodstudio.dll (00007FFF55CA0000), size: 3276800 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 0.2.0.0
C:\Windows\SYSTEM32\MSACM32.dll:MSACM32.dll (00007FFF7A740000), size: 114688 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\wdmaud.drv:wdmaud.drv (00007FFF89050000), size: 278528 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\ksuser.dll:ksuser.dll (00007FFF6C5C0000), size: 36864 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\msacm32.drv:msacm32.drv (00007FFF914B0000), size: 53248 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\midimap.dll:midimap.dll (00007FFF89040000), size: 40960 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\IPHLPAPI.DLL:IPHLPAPI.DLL (00007FFF92BE0000), size: 229376 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\NSI.dll:NSI.dll (00007FFF948E0000), size: 32768 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\dhcpcsvc6.DLL:dhcpcsvc6.DLL (00007FFF8DD60000), size: 90112 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\dhcpcsvc.DLL:dhcpcsvc.DLL (00007FFF8DD40000), size: 106496 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\DNSAPI.dll:DNSAPI.dll (00007FFF92C20000), size: 778240 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.441
C:\Windows\System32\rasadhlp.dll:rasadhlp.dll (00007FFF8C990000), size: 40960 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\fwpuclnt.dll:fwpuclnt.dll (00007FFF8C8A0000), size: 466944 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\System32\uiautomationcore.dll:uiautomationcore.dll (00007FFF75EC0000), size: 2097152 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 7.2.17134.112
C:\Windows\System32\OLEACC.dll:OLEACC.dll (00007FFF8CA30000), size: 438272 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 7.2.17134.1
C:\Windows\SYSTEM32\dbghelp.dll:dbghelp.dll (00007FFF5C550000), size: 1871872 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.1
C:\Windows\SYSTEM32\SspiCli.dll:SspiCli.dll (00007FFF93500000), size: 196608 (result: 0), SymType: โ€˜-deferred-โ€™, PDB: โ€˜โ€™, fileVersion: 10.0.17134.376
========== OUTPUTTING STACK TRACE ==================
0x00007FFF55D6A521 (fmodstudio) FMOD_Studio_VCA_SetVolume
0x00007FFF55D6A3CD (fmodstudio) FMOD_Studio_VCA_SetVolume
ERROR: SymGetSymFromAddr64, GetLastError: '่ฏ•ๅ›พ่ฎฟ้—ฎๆ— ๆ•ˆ็š„ๅœฐๅ€ใ€‚
โ€™ (Address: 00007FFF55D03491)
0x00007FFF55D03491 (fmodstudio) (function-name not available)
0x00007FFF55D7E448 (fmodstudio) FMOD_Studio_VCA_SetVolume
0x00007FFF55D7DBC8 (fmodstudio) FMOD_Studio_VCA_SetVolume
0x00007FFF55D7DC8C (fmodstudio) FMOD_Studio_VCA_SetVolume
โ€™ (Address: 00007FFF55D0660D)
0x00007FFF55D0660D (fmodstudio) (function-name not available)
โ€™ (Address: 00007FFF55D10112)
0x00007FFF55D10112 (fmodstudio) (function-name not available)
โ€™ (Address: 00007FFF55D10353)
0x00007FFF55D10353 (fmodstudio) (function-name not available)
โ€™ (Address: 00007FFF55CF4343)
0x00007FFF55CF4343 (fmodstudio) (function-name not available)
0x00007FFF55D68026 (fmodstudio) FMOD_Studio_VCA_SetVolume
0x00007FFF55DC5821 (fmodstudio) FMOD::ChannelI::validate
0x00007FFF55D9E3E6 (fmodstudio) FMOD::DSP::showConfigDialog
0x00007FFF55E9F6B7 (fmodstudio) FMOD::GeometryI::setUserData
0x00007FFF55E9F85E (fmodstudio) FMOD::GeometryI::setUserData
0x00007FFF96A84034 (KERNEL32) BaseThreadInitThunk
0x00007FFF97363691 (ntdll) RtlUserThreadStart
========== END OF STACKTRACE ===========
Are you able to reproduce this using โ€˜Development buildโ€™?
