I am new to Fmod and C# in general, so bear with me when I say that (I think) I’m changing a parameter in Unity during playback, and it isn’t responding properly. I’ve confirmed that the input values I need are being properly calculated, and that the values I’m setting are being changed to the proper numbers. I think I might not be referring to the event or parameter properly but because I don’t get any errors I have no idea.
using UnityEngine;
using System.Collections;
public class VolumeLookController : MonoBehaviour {
public GameObject musicBox;
public GameObject myCamera;
private float distance;
float angleAway;
private FMOD.Studio.EventInstance Music;
private FMOD.Studio.ParameterInstance LookVolume;
// Use this for initialization
void Start () {
Music = FMODUnity.RuntimeManager.CreateInstance ("event:/Music/Music");
Music.getParameter ("LookVolume", out LookVolume);
void Update () {
angleAway = Vector3.Angle(myCamera.transform.forward, musicBox.transform.position - myCamera.transform.position)/180;
float printOut;
//LookVolume.setValue (angleAway);
//LookVolume.getValue (out blegh);
Music.setParameterValue ("LookVolume", angleAway);
Music.getParameterValue ("LookVolume", out printOut);
print (printOut);
With this code I’m fed a large stream of numbers confirming that LookVolume is being set to the proper numbers, but the game is unresponsive. Both methods (commented and uncommented) used for setting and printing the value seem to act identically, and neither works properly. What am I missing?
