Xbox360 Custom Soundtrack TCR
In the FMOD Designer user manual under the Event Categories section, it states:
"The music category has a different, yet important purpose. Microsoft requires a title’s soundtrack be replaceable with the end-user’s own music files. The Xbox 360 allows end-users to import their own music using the Xbox 360 dashboard.
To comply with this requirement, all non-game related (soundtrack) music should be placed in the ‘music’ category. This allows the FMOD engine to automatically suspend the playback of audio in the music category and instead use the end-user supplied music tracks."
I could not find anything about how to follow this requirement in the FMOD Studio user manual, does similar functionality exist?
Cheers.
There is not quite the same functionality in Studio. If you create a group bus called music in the studio tool you have two options.
Poll the system yourself once a frame and mute/pause the bus yourself
FMOD::Studio::Bus* musicBus;
studioSystem->getBus("bus:/music", &musicBus);
BOOL titlehascontrol = FALSE;
XMPTitleHasPlaybackControl(&titlehascontrol);
if (titlehascontrol)
    musicBus->setMute(false);
else
    musicBus->setMute(true);
Create a dummy channel group with the correct name for the driver to control it automatically
// Get the music bus
musicBus->lockChannelGroup();
studioSystem->flushCommands();
// Get the channel group for the music bus as well as it's parent
FMOD::ChannelGroup* musicBusCG;
musicBus->getChannelGroup(&musicBusCG);
FMOD::ChannelGroup* musicBusParentCG;
musicBusCG->getParentGroup(&musicBusParentCG);
// Create a new channel group with the correct name for the TCR code in the driver
// to find it and insert between the music bus channel group and it's parent
FMOD::ChannelGroup* tcrMusicCG;
lowLevelSystem->createChannelGroup("music", &tcrMusicCG);
musicBusParentCG->addGroup(tcrMusicCG);
tcrMusicCG->addGroup(musicBusCG);
Thanks Nicholas.
