4.16 support ETA?
Is there an ETA for when I’ll be able to download the FMOD plugin for 4.16? I know you guys usually wait until the first hotfix but 4.16.1 was released quite some time ago.
Thanks,
-Adrian
If you’re not sure about a feature , either subscribe to the newsletter or use http://www.fmod.org/documentation/#content/generated/common/revision.html, it states that 4.16 support has been out for a while now.
regards,
Thanks for the answer but i was referring to the compiled plugins that you download from here: http://www.fmod.org/download/
Best,
-Adrian
Thats what I was talking about, but it does look like the website has a typo with the version number. I’ve updated it.
Thanks Brett,
All good now :slight_smile:
Best,
-Adrian
Here’s a quick video that shows you how to use the 4.15 source and compile it for your 4.16 games. It only takes a few minutes. Hope that helps.
Enjoy!
-TornadoTwins
nice one, comprehensive answer!
Thanks Brett
Thanks for the video. I tried to follow along on Mac / Xcode with no luck unfortunately. I used “Development Editor” for command line builds and built with MacOS 10.12 as the target but still get the same error when running.
I appreciate you spending the time to make the video though! I think I’ll just have to hang on until there’s an officially compiled version.
Chris.
