Add Parameter Modulation AHDSR to Fade a Track
#1
Hi All, I’m trying to put a parameter on FMOD that is between 0 and 1, and fade in a track when its value is 1. The problem I have is that I can’t make the fade, because when the parameter is 1 the volume goes from -inf to 0db immediatly.
I think I can do this using a modulator in the parameter (right click to parameter and add modulation AHDSR, but when I click nothing appears… Someone knows what happens?
Thanks in advance
#2
I’m referring to the first title on page 118 from the manual (Parameter Modulation), but I don’t know how to manage.
#3
It’s done, it doesn’t apply if you don’t stop and replay the scene. Thanks
