AIF file fails to load with FMOD_ERR_FORMAT (AIF-C support?)
FMOD 2.00.00 is failing to load an AIF file with the error, FMOD_ERR_FORMAT. The file plays fine in VLC.
The debug output from the fmod error callback is;
2019-10-01T14:30:07.460-07:00: !!!!! Audio: Header check failed. Not an FSB5
2019-10-01T14:30:07.461-07:00: Trace :  < CodecFSB5::readHeader [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_fsb5.cpp:237]  < AudioFileInfo
2019-10-01T14:30:07.461-07:00: !!!!! Audio: failed to open as ogg
2019-10-01T14:30:07.462-07:00: Trace :  < CodecOggVorbis::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_oggvorbis.cpp:356]  < A
2019-10-01T14:30:07.463-07:00: !!!!! Audio: 'M.K.' etc ID check failed [????]
2019-10-01T14:30:07.463-07:00: Trace :  < CodecMOD::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_mod.cpp:1242]  < AudioFileInf
2019-10-01T14:30:07.464-07:00: !!!!! Audio: 'SCRM' ID check failed [2-bi]
2019-10-01T14:30:07.464-07:00: Trace :  < CodecS3M::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_s3m.cpp:1550]  < AudioFileInf
2019-10-01T14:30:07.464-07:00: !!!!! Audio: 'Extended Module: ' ID check failed [FORM]
2019-10-01T14:30:07.465-07:00: Trace :  < CodecXM::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_xm.cpp:2207]  < AudioFileInfo:
2019-10-01T14:30:07.465-07:00: !!!!! Audio: 'IMPM' etc ID check failed [FORM]
2019-10-01T14:30:07.466-07:00: Trace :  < CodecIT::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_it.cpp:4092]  < AudioFileInfo:
2019-10-01T14:30:07.466-07:00: !!!!! Audio: 'HThd' ID check failed [FORM]
2019-10-01T14:30:07.467-07:00: Trace :  < CodecMIDI::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_midi.cpp:2873]  < AudioFileI
2019-10-01T14:30:07.467-07:00: !!!!! Audio: failed to open as mpeg
2019-10-01T14:30:07.468-07:00: Trace :  < CodecMPEG::openInternal [c:\jk\workspace\Build__2.0__API_Win\core_api\src\fmod_codec_mpeg.cpp:478]  < AudioFileIn
Output from MediaInfo
General
Complete name                            : C:\Users\dada\Downloads\AIFF 32 441.aif
Format                                   : AIFF
Format/Info                              : Apple/SGI
File size                                : 119 MiB
Duration                                 : 5 min 54 s
Overall bit rate mode                    : Constant
Overall bit rate                         : 2 823 kb/s
Audio
Format                                   : PCM
Format settings                          : Big
Codec ID                                 : fl32
Codec ID/Hint                            :
Bit rate mode                            : Constant
Bit rate                                 : 2 822 kb/s
Channel(s)                               : 2 channels
Sampling rate                            : 44.1 kHz
Bit depth                                : 32 bits
Stream size                              : 119 MiB (100%)
It looks like the file is compressed version of AIF, AIFC from the file signature, FORM…AIFC
Is AIFC supported?
AIF-C is supported, but only trivially for compression type “NONE” or “sowt”, not “fl32” like your file.
I can issue a feature request for that variant if you like?
Thanks, good to know.
Yes a request would be great.
