It is a know bug for Android 4.0.0 to 4.0.3 that when defining multiple cpu architectures ( APP_ABI := armeabi armeabi-v7a ), system will load library for armeabi even if it should use armeabi-v7a (https://code.google.com/p/android/issue … l?id=25321), resulting in corrupted sounds played by fmod.
I’ve tried a couple of workarounds found on the net but none working.
Unluckily I don’t have an Android with the old armeabi architecture for testing, but on a 4.0.3 I can test on I get this behaviour:
defining APP_ABI := armeabi-v7a , sounds work fine
defining APP_ABI := armeabi armeabi-v7a sounds are completely corrupted
according to the known bug of 4.0.0 to 4.0.3 Androids with armeabi-v7a architecture, if the apk package contains both armeabi and armeabi-v7a binaries, armeabi libraries will be loaded when calling System.loadLibrary(“fmod”) and System.loadLibrary(“fmodstudio”) instead of armeabi-v7a ones.
It’s not great that a bug exists causing armeabi to be selected when armeabi-v7a should be but I am concerned that armeabi is producing corrupted sound. It should be fine (albeit a little more expensive CPU wise).
To try and reproduce this corruption I forced armeabi on my Nexus 5 with “APP_ABI := armeabi” but the FMOD examples worked as expected (no corruption), can you confirm that the examples are corrupted when you do this?
I just launched the “simple_event” sample project built with APP_ABI := armeabi only on a 4.1.2 Android and sounds played are corrupted ( buzzing sounds ).
I ran into this when testing on a Kindle Fire HD (based on 4.2.2) with the armeabi FMOD shared library. Sounds played as noise. Once I switched to the armeabi-v7 library, everything worked as expected.
