In the record example, the getRecordNumDrivers method always returns numDrivers as 0, and the solution. (Android)
Some functionality inside of FMOD will require you set relevant permissions in your AndroidManifest.xml file.
- Recording - to make use of the System::recordStart API use android.permission.RECORD_AUDIO.
Also the Audio Track output mode currently does not support recording, please use the OpenSL output mode for this.
https://fmod.com/resources/documentation-api?page=content/generated/platform_android/basics.html#/
I have configured the permissions required for the record example, but the number of test microphone devices is still 0.
record.cpp
System ->setOutput(FMOD_OUTPUTTYPE_OPENSL) has been set.
Make sure system->setOutput is called before system->init otherwise it will not do anything. You can confirm that it has worked by calling system->getOutput.
Thank you very much for your help! The problem has been solved!
