I’m using FMOD Studio Programmer’s API with iOS (tested version 1.06.07 and 1.06.10) and I get this error:
FMOD error! (28) An error occurred that wasn’t supposed to. Contact support.
This started happening when I tried implementing Apple’s ReplayKit. It happens right after calling RPScreenRecorder::startRecordingWithMicrophoneEnabled. Audio skips and then cuts out completely and doesn’t return until I restart the application. Apple’s RPScreenRecorder also fails and stops recording.
Any ideas?
Thank you,
Luigi
Log1:
2015-09-29 09:23:25.726 Apocalypse Meow[1464:685917] STARTED REPLAY KIT RECORDING
[LOG] SoundI::release : menu.m4a (0x15b50f158)
[LOG] SoundI::release : remove stream samples. (0x15b50f158)
[LOG] SoundI::release : (0x15b50f8a8)
[LOG] SoundI::release : release codec. (0x15b50f158)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Apocalypse Meow.app/Audio/Level_2_song.m4a : mode 0000008a
[ERR] CodecFSB5::headerReadCheck : Header check failed. Not an FSB5
[ERR] CodecVAG::openInternal : 'VAG' ID check failed [[ERR] CodecOggVorbis::openInternal : failed to open as ogg
[ERR] CodecMOD::openInternal : 'M.K.' etc ID check failed [v??]
[ERR] CodecS3M::openInternal : 'SCRM' ID check failed [????]
[ERR] CodecXM::openInternal : 'Extended Module: ' ID check failed [???]
[ERR] CodecIT::openInternal : 'IMPM' etc ID check failed [???]
[ERR] CodecMIDI::openInternal : 'HThd' ID check failed [???]
[LOG] SystemI::createSoundInternal : Format has 0 subsounds.
[LOG] SystemI::createSoundInternal : Create as FMOD_CREATESTREAM
[LOG] System::createSoundInternal : decode buffersize = 17408 : blocksize = 256 : format = 2
[LOG] SystemI::createSample : mode 0000008a length 17408 samples, lengthbytes 1249859
[LOG] SystemI::createSample : subsamples = 1, channels = 2
[LOG] SystemI::createSample : subsample 0. output = 0x15b34f478
[LOG] OutputSoftware::createSample : lengthpcm 17408, lengthbytes 1249859, channels 2, format 2, freq 44100, mode 0000008a
[LOG] System::createSoundInternal : Seek stream to start
[LOG] System::createSoundInternal : flush stream buffer
[ERR] CodecAudioQueue::readInternal : Cannot offline render audio queue. (err: -308)
[LOG] SoundI::release : (0x15b472ec8)
[LOG] SoundI::release : remove stream samples. (0x15b472ec8)
[LOG] SoundI::release : (0x15b473198)
[LOG] SoundI::release : release codec. (0x15b472ec8)
[ERR] CodecAudioQueue::closeInternal : Cannot dispose audio queue. (err: -66671)
FMOD error! (28) An error occurred that wasn't supposed to. Contact support.
Log2:
Wed Sep 30 09:11:51 2015 - Level::load - suspending audio mixer.
[LOG] SystemI::mixerSuspend : Suspending output.
LOADING COMPRESSED SAMPLE
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/670ACF38-1565-4D2F-8A78-9C93A9FFCCD7/Apocalypse Meow.app/Audio/human_detected.fsb : mode 00000088
[LOG] SystemI::createSoundInternal : Format has 1 subsounds.
[LOG] SystemI::createSample : mode 0000008a length 17408 samples, lengthbytes 91840
[LOG] SystemI::createSample : subsample 0. output = 0x139990be8
[LOG] OutputSoftware::createSample : lengthpcm 17408, lengthbytes 91840, channels 2, format 2, freq 44100, mode 0000008a
[LOG] System::createSoundInternal : 1 subsounds detected.
[LOG] System::createSoundInternal : flush successful.
[LOG] System::createSoundInternal : switch file handle from small blocking single buffered to large nonblocking doublebuffered.
[LOG] SystemI::createSoundInternal : done. OpenState now = FMOD_OPENSTATE_READY.
... trimmed, a bunch more audio files are loaded ...
LOAD TIME IN SECONDS SECONDS: 0.281481
Wed Sep 30 09:11:56 2015 - Level::initialize - Starting replay record.
2015-09-30 09:11:56.835 Apocalypse Meow[2258:967808] STARTED RECORDING
[LOG] SoundI::release : menu.m4a (0x1399e66a8)
[LOG] SoundI::release : remove stream samples. (0x1399e66a8)
[LOG] SoundI::release : (0x1399e6978)
[LOG] SoundI::release : release codec. (0x1399e66a8)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/670ACF38-1565-4D2F-8A78-9C93A9FFCCD7/Apocalypse Meow.app/Audio/Level_2_song.m4a : mode 0000008a
[LOG] SoundI::release : (0x139a92d88)
[LOG] SoundI::release : remove stream samples. (0x139a92d88)
[LOG] SoundI::release : (0x139a93058)
[LOG] SoundI::release : release codec. (0x139a92d88)
FMOD error! (31) An invalid parameter was passed to this function.
2015-09-30 09:11:57.882 Apocalypse Meow[2258:967913] The operation couldn’t be completed. (com.apple.ReplayKit.RPRecordingErrorDomain error -5804.)
2015-09-30 09:12:00.044 Apocalypse Meow[2258:967917] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
Wed Sep 30 09:12:01 2015 - Level::startGame - resuming audio mixer.
[LOG] SystemI::mixerResume : Resuming output.
[ERR] OutputCoreAudio::suspend : Cannot start audio unit. (err: -50)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/670ACF38-1565-4D2F-8A78-9C93A9FFCCD7/Apocalypse Meow.app/Audio/Dialog/stay alert only a hero can survive.fsb : mode 00000088
[LOG] SystemI::createSample : mode 0000008a length 17408 samples, lengthbytes 211136
[LOG] OutputSoftware::createSample : lengthpcm 17408, lengthbytes 211136, channels 2, format 2, freq 44100, mode 0000008a
[LOG] SoundI::getSubSound : sound 0x139b44f88. Subsound index 0 / 1
[LOG] SoundI::release : thruster_flyby (0x139b1ab68)
[LOG] SoundI::release : remove stream samples. (0x139b1ab68)
[LOG] SoundI::release : thruster_flyby (0x139b1ae38)
[LOG] SoundI::release : release subsounds. (0x139b1ab68)
[LOG] SoundI::release : thruster_flyby (0x139b1b1e8)
[LOG] SoundI::release : release codec. (0x139b1ab68)
Log 3 (PlayAndRecord)
SUSPEND
RECORD
2015-09-30 15:10:28.553 Apocalypse Meow[2462:1053844] STARTED RECORDING
RESUME
[ERR] CodecAudioQueue::setPositionInternal : Cannot start audio queue. (err: -308)
2015-09-30 15:10:30.810 Apocalypse Meow[2462:1053886] The operation couldn’t be completed. (com.apple.ReplayKit.RPRecordingErrorDomain error -5804.)
2015-09-30 15:10:31.250 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
COMPLETE LEVEL LOAD
HttpRequest::run(http://www.google-analytics.com/collect)
[LOG] SoundI::release : menu.m4a (0x1583b2d08)
[LOG] SoundI::release : remove stream samples. (0x1583b2d08)
[LOG] SoundI::release : (0x1583b30b8)
[LOG] SoundI::release : release codec. (0x1583b2d08)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/AA9E42A0-0147-41E7-BE70-F7443FD2C898/Apocalypse Meow.app/Audio/Level_2_song.m4a : mode 0000008a
[LOG] SystemI::createSample : subsample 0. output = 0x1545bcb88
[LOG] SystemI::createSoundInternal : No name found in file, use filename.
2015-09-30 15:10:46.292 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:11:01.244 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:11:16.411 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:11:31.263 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:11:46.316 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:12:01.282 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:12:16.420 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:12:32.419 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:12:46.335 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:13:01.371 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:13:16.321 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:13:31.373 Apocalypse Meow[2462:1053950] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
Log 4 (PlayAndRecord)
SUSPEND
[ERR] CodecAudioQueue::processAudioQueue : Cannot enqueue buffer for audio queue. (err: -66632)
RECORD
2015-09-30 15:07:33.152 ApocalypseMeow[2446:1051816] STARTED RECORDING
RESUME
2015-09-30 15:07:33.780 ApocalypseMeow[2446:1051897] The operation couldn’t be completed. (com.apple.ReplayKit.RPRecordingErrorDomain error -5804.)
COMPLETE LEVEL LOAD
[LOG] SoundI::release : menu.m4a (0x1621f55b8)
[LOG] SoundI::release : remove stream samples. (0x1621f55b8)
[LOG] SoundI::release : (0x16241dd48)
[LOG] SoundI::release : release codec. (0x1621f55b8)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/A1F9FCA9-550C-4DE8-BE66-BA84641A498D/ApocalypseMeow.app/Audio/Level_2_song.m4a : mode 0000008a
[LOG] SystemI::createSample : subsample 0. output = 0x15f8c1378
2015-09-30 15:07:40.418 ApocalypseMeow[2446:1051916] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
2015-09-30 15:07:55.358 ApocalypseMeow[2446:1051916] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
Log 5 (Ambient, probably these errors are expected, but just in case)
2015-09-30 15:05:48.728 ApocalypseMeow[2438:1050586] STARTED RECORDING
RESUME
2015-09-30 15:05:49.364 ApocalypseMeow[2438:1050692] The operation couldn’t be completed. (com.apple.ReplayKit.RPRecordingErrorDomain error -5804.)
COMPLETE LEVEL LOAD
2015-09-30 15:05:49.395 ApocalypseMeow[2438:1050586] 15:05:49.395 ERROR: [0x1a0ce1000] AVAudioSessionUtilities.h:111: GetProperty: AudioSessionGetProperty ('othr') failed with error: '!ini'
2015-09-30 15:05:49.395 ApocalypseMeow[2438:1050586] 15:05:49.395 ERROR: [0x1a0ce1000] AVAudioSessionUtilities.h:124: GetProperty_DefaultToZero: AudioSessionGetProperty ('othr') failed with error: '!ini'
2015-09-30 15:05:49.410 ApocalypseMeow[2438:1050586] 15:05:49.410 ERROR: [0x1a0ce1000] AVAudioSessionUtilities.h:111: GetProperty: AudioSessionGetProperty ('othr') failed with error: '!ini'
2015-09-30 15:05:49.410 ApocalypseMeow[2438:1050586] 15:05:49.410 ERROR: [0x1a0ce1000] AVAudioSessionUtilities.h:124: GetProperty_DefaultToZero: AudioSessionGetProperty ('othr') failed with error: '!ini'
Log 6
2015-09-30 15:55:42.093 Apocalypse Meow[2488:1064169] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
SUSPEND
RECORD
2015-09-30 15:55:54.720 Apocalypse Meow[2488:1064036] STARTED RECORDING
2015-09-30 15:55:57.068 Apocalypse Meow[2488:1064169] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
RESUME
2015-09-30 15:56:04.828 Apocalypse Meow[2488:1064141] The operation couldn’t be completed. (com.apple.ReplayKit.RPRecordingErrorDomain error -5804.)
2015-09-30 15:56:12.067 Apocalypse Meow[2488:1064169] NSURLSession/NSURLConnection HTTP load failed (kCFStreamErrorDomainSSL, -9802)
COMPLETE LEVEL LOAD
[LOG] SoundI::release : menu.m4a (0x140d00728)
[LOG] SoundI::release : remove stream samples. (0x140d00728)
[LOG] SoundI::release : (0x140c1d8f8)
[LOG] SoundI::release : release codec. (0x140d00728)
[LOG] SystemI::createSoundInternal : filename = /var/mobile/Containers/Bundle/Application/284AF2DD-0D04-41F0-A6FA-341239BD9A15/Apocalypse Meow.app/Audio/Level_2_song.m4a : mode 0000008a
[LOG] SystemI::createSample : subsample 0. output = 0x140b6c638
