I would like to use my Focusrite Scarlett 18i20 audio interface (with current drivers and firmware) as low-latency multi-channel output system for FMOD Studio.
My software is written in C#, consequently it uses the C# wrapper (FMOD version 1.03.06, but seemingly there were no changes regarding my issues).
If I set the speaker system to 5.1, it is reverted to stereo. Also I noticed that Windows lists the Scarlett only as stereo device, is there any possibility to “force”
FMOD to a certain speaker configuration?
Ideally I would like to use the ASIO driver of the interface. Unfortunately when I select it in the C# wrapper with
// Create a System object and initialize.
result = FMOD.Studio.System.create(out FMOD_system);
result = FMOD_system.getLowLevelSystem(out FMOD_lowlevel);
// Trying to use ASIO
result = FMOD_lowlevel.setOutput(FMOD.OUTPUTTYPE.ASIO);
result = FMOD_system.initialize(128, FMOD.Studio.INITFLAGS.NORMAL , FMOD.INITFLAGS.PROFILE_ENABLE & FMOD.INITFLAGS._3D_RIGHTHANDED & FMOD.INITFLAGS.CHANNEL_DISTANCEFILTER & FMOD.INITFLAGS.CHANNEL_LOWPASS, (IntPtr) 0);
result = FMOD_lowlevel.setSoftwareFormat(44100, FMOD.SPEAKERMODE._5POINT1, 6);
everything looks OK, but when I load a bank in non-blocking mode the application hangs. The same thing works nicely if I use the WASAPI driver.
What else could I do / try?
Thanks, Florian
