Hi Everyone, is there a functional script that creates a track and auto name’s it after the file that i importing the last? I have a huge session and i have always to rename all of my tracks when importing a new file. It takes forever.
I don’t have a script on hand, but I’d be happy to provide some pointers or basic code snippets. Can I get you to elaborate on what the desired behavior is? For example:
- What specifically are you trying to rename?
- Whole events
- Individual audio tracks
- etc.
- When is it that you want to trigger the renaming?
- File import
- Replacing an existing file with a new one
- Adding a new file to an event or track
- etc.
A short series of steps explaining what exactly you’re trying to do would be great.
thanks for the answer. One of our programmers helped me out making a script, that auto names tracks with a shortcut once you have selected a audio clip on your track. You can change the shortcut in the script. right now it is alt&2 on mac. Is here a pool with already existing script for sharing my script?
There’s no pool, but you’re more than welcome to share the script in this thread.
of course, feel free to use it.
/// Renames tracks based on their clips
/// If a track is selected, it will rename based on the first clip
/// If a specific clip is selected it will rename its track after it
studio.menu.addMenuItem({
name: "Track Name from Clip",
isEnabled: hasTrackOrSoundSelected,
execute: trackNameFromClip,
keySequence: "Ctrl+F2",
function trackNameFromClip()
var selectedObjects = studio.window.editorSelection();
for(var i = 0; i < selectedObjects.length; i++)
var selectedObject = selectedObjects[i];
if(selectedObject.isOfExactType("GroupTrack")) // if track is selected, name it based on the first sound
nameTrackBasedOnFirstSound(selectedObject);
else if(selectedObject.isOfType("ManagedObject")) // if specific instrument on track is selected, name its track after it
nameTrackOfSoundBasedOnSound(selectedObject);
// check if track or sound is selected
function hasTrackOrSoundSelected()
return true;
else if(selectedObject.isOfType("Sound"))
return true;
else if(selectedObject.isOfExactType("EventSound"))
return true;
return false;
function nameTrackBasedOnFirstSound(track)
var modules = track.modules;
for(var i = 0; i < modules.length; i++)
var module = modules[i];
if(module.isOfType("Sound") || module.isOfExactType("EventSound"))
var soundName = getModuleName(module);
if(soundName && soundName.length > 0)
console.log("Name Track " + track.mixerGroup.name + " based on first sound " + soundName);
track.mixerGroup.name = soundName;
return;
console.log("Track " + track.mixerGroup.name + " has no sounds on it to name it after.");
function nameTrackOfSoundBasedOnSound(module)
var moduleName = getModuleName(module);
if(moduleName && moduleName.length > 0)
var mixerGroup = module.audioTrack.mixerGroup;
console.log("Name Track " + mixerGroup.name + " of sound " + moduleName + " based on the sound.");
mixerGroup.name = moduleName;
function getModuleName(module)
if(module.name && module.name.length > 0)
return module.name;
if(module.isOfExactType("SingleSound"))
if(module.audioFile)
return GetAssetName(module.audioFile);
else if(module.isOfExactType("MultiSound")) // for multi-sound instruments, use the name of the first sound
if(module.sounds && module.sounds.length > 0)
return getModuleName(module.sounds[0]);
else if(module.isOfExactType("EventSound"))
return module.event.name;
return null;
function GetFullAssetName(asset){
var assetPath = asset.getAssetPath().split('/');
return assetPath.pop()
function GetAssetName(asset){
var assetName = GetFullAssetName(asset);
var lastIndexOf = assetName.lastIndexOf('.');
return assetName.slice(0, lastIndexOf);
