Destination Marker Sequential Labelling in 2.0
I’ve noticed in the new version of fmod that if I copy marker “A”, it pastes it as “B”, similarly “A1” becomes “A1 B”, etc.
Is there a way to turn off this automatic sequential labelling? At the moment I have to go through and edit every single one of my markers manually.
I didn’t find an option to do this, but you can easily use a script to batch rename markers (had the same problem a few days ago).
  1. Add a scripts folder to your project in explorer/finder and create a new .js file.
  2. Add this code to the file:
studio.menu.addMenuItem({
isEnabled: function () {
var markers = studio.window.editorSelection();
return markers
execute: function () {
    var markerName = studio.system.getText("Marker Name", "");
    for (i = 0; i < markers.length; i++) {
        markers[i].name = markerName
  1. Reload your scripts by clicking on Scripts->Reload (Menu)
  2. Select the markers you want to rename.
  3. Run the script by clicking on Scripts->Scripts->RenameMarkers (Menu), insert your desired name in the pop up, click okay and your markers should be renamed.
Thanks so much for your help - much appreciated :slight_smile:
