Hi everyone!
So I have a WALKMAN in my game that’s using an AudioTable together with Programmer Instrument to play music tracks. The tracks play and everything works except one crucial part, autoplay.
I know which key is the next one I want to play, I just simply can’t get it to work without freezing the game.
After a track has been played I want it to play the next one from an audio table. I can provide the next key no problem but everything seems to crash. This is my programmer instrument callback, everything is matching FMOD’s example except case EVENT_CALLBACK_TYPE.DESTROYED: where I try to play the next in my list.
Doing this freezes the game completely, anyone got a clue on how I can implement this?
Here’s my programmer music callback
[AOT.MonoPInvokeCallback(typeof(EVENT_CALLBACK))]
static RESULT MusicEventCallback(EVENT_CALLBACK_TYPE type, EventInstance instance, IntPtr parameterPtr)
// Retrieve the user data
instance.getUserData(out var stringPtr);
// Get the string object
GCHandle stringHandle = GCHandle.FromIntPtr(stringPtr);
string key = stringHandle.Target as string;
switch (type)
case EVENT_CALLBACK_TYPE.CREATE_PROGRAMMER_SOUND:
const MODE soundMode = MODE.LOOP_NORMAL | MODE.CREATECOMPRESSEDSAMPLE | MODE.NONBLOCKING;
var parameter = (PROGRAMMER_SOUND_PROPERTIES) Marshal.PtrToStructure(parameterPtr, typeof(PROGRAMMER_SOUND_PROPERTIES));
var keyResult = RuntimeManager.StudioSystem.getSoundInfo(key, out var dialogueSoundInfo);
if (keyResult != RESULT.OK)
break;
var soundResult = RuntimeManager.CoreSystem.createSound(dialogueSoundInfo.name_or_data, soundMode | dialogueSoundInfo.mode, ref dialogueSoundInfo.exinfo, out var dialogueSound);
if (soundResult == RESULT.OK)
parameter.sound = dialogueSound.handle;
parameter.subsoundIndex = dialogueSoundInfo.subsoundindex;
Marshal.StructureToPtr(parameter, parameterPtr, false);
break;
case EVENT_CALLBACK_TYPE.DESTROY_PROGRAMMER_SOUND:
var sound = new Sound {handle = parameter.sound};
sound.release();
CassettePlayer.instance.PlayNext(); // Play next song
break;
// Now the event has been destroyed, unpin the string memory so it can be garbage collected
stringHandle.Free();
break;
return RESULT.OK;
