Batch rename Labeled Parameter Labels
Has anyone made a script to do the following:
Labeled Parameter contains many labels with name ‘Old_Label_X’ where ‘X’ is some number.
Requirement is to batch update all labels in the parameter to ‘New_Label_X’.
Preferably this would be run from the Scripts menu after selecting the target parameter in the Parameters Browser.
Something like the Batch Rename script with a pop-up window for input would be good
I can’t find a way to do this with the existing Batch Rename script.
Thanks for the details!
For Labeled parameters, the label names live in the enumerationLabels array, and need to be updated by copying the array and reassigning it back to the parameter.
I have modified the original batch rename script to make it work for the selected labeled parameter’s labels.
You can run it via Scripts > FMOD Examples > Batch Rename Labels
studio.menu.addMenuItem({
    name: "FMOD Examples\\Batch Rename Labels",
    isEnabled: function () {
        var cur = studio.window.browserCurrent();
        return cur && cur.parameter && cur.parameter.enumerationLabels;// Make sure the selected item is label parameter
    execute: function () {
        var p = cur.parameter;
        if (!p || !p.enumerationLabels) {
            studio.system.message("Please select a Labeled Parameter.");
            return;
        var findStr = "";
        var replaceStr = "";
        var dialogRoot = null;
        //Update the preview
        function updatePreview() {
            if (!dialogRoot) return;
            var labels = p.enumerationLabels || [];
            var lines = [];
            for (var i = 0; i < labels.length; i++) {
                if (typeof labels[i] === "string" && labels[i].indexOf(findStr) === 0) {
                    var newName = replaceStr + labels[i].substring(findStr.length);
                    lines.push(labels[i] + "  →  " + newName);
            var preview = dialogRoot.findWidget("m_preview");
            if (!preview) return;
            preview.setHtml(lines.length ? lines.join("<br/>") : '<font color="Gray">(no matching labels)</font>');
        studio.ui.showModalDialog({
            windowTitle: "Batch Rename Enum Labels",
            windowWidth: 340,
            windowHeight: 230,
            widgetType: studio.ui.widgetType.Layout,
            layout: studio.ui.layoutType.VBoxLayout,
            contentsMargins: { left: 8, top: 8, right: 8, bottom: 8 },
            spacing: 6,
            // Get the dialogRoot
            onConstructed: function () { dialogRoot = this; updatePreview(); },
            items: [
                { widgetType: studio.ui.widgetType.Label, text: "Find" },
                    widgetType: studio.ui.widgetType.LineEdit,
                    widgetId: "m_find",
                    text: findStr,
                    onTextEdited: function () { findStr = this.text(); updatePreview(); }
                { widgetType: studio.ui.widgetType.Label, text: "Replace with" },
                    widgetId: "m_replace",
                    text: replaceStr,
                    onTextEdited: function () { replaceStr = this.text(); updatePreview(); }
                { widgetType: studio.ui.widgetType.Label, text: "Preview" },
                    widgetType: studio.ui.widgetType.TextEdit,
                    widgetId: "m_preview",
                    isReadOnly: true,
                    minimumHeight: 90,
                    html: '<font color="Gray">(type Find/Replace to preview changes)</font>'
                    widgetType: studio.ui.widgetType.PushButton,
                    text: "Apply",
                    onClicked: function () {
                        //Copy, modify and reassign all target labels
                        var labels = p.enumerationLabels.slice();
                        var changed = 0;
                                labels[i] = replaceStr + labels[i].substring(findStr.length);
                                changed++;
                        if (changed === 0) {
                            studio.system.message("No labels matched: " + findStr);
                            this.closeDialog();
                            return;
                        p.enumerationLabels = labels;
                        this.closeDialog();
Hope this helps! Let me know if it works.
That’s awesome, thanks for that.
I’ll give this a go and let you know if it works.
@li_fmod Thanks so much. This works brilliantly.
