Build changed only?
Is there a way to build only the banks that contain data I’ve modified in a project, without having to manually select them in the Banks tab? Being able to hit a hotkey for “Build Only Changed Banks” would be a wonderful time saver. I’m hoping this exists and I just haven’t found it. Thanks!
There should already be a kind of system in place that uses the cache folder to speed up building. Could you give some more information on the following:
  • Are you using live update?
  • How long does it take to build all your banks with and without a cache?
  • How long does building take with no file changes for the banks?
Hi, are you still experiencing banks building slowly?
I am using live update.
It takes quite a while, but we have a ton of banks in our project. After talking to our audio coder, I think that’s what’s happening here.
Sorry, could you please clarify what “I think that’s what’s happening here” refers to?
Meaning I think our issue is simply the number of banks in our project causing the build to take quite a while, rather than the building of each individual bank being too slow.
Ah, yes. Your programmer is correct, lots of files will take a while to finish compared to fewer larger size banks.
