Can effects on Programmable instrument be adjusted real time with parameters in Unity
I am trying to adjust effect on programmable instrument at runtime, there is no changes on this effect when I adjust the parameters attached to it via unity.
Can I adjust effect on programmable instrument at runtime via unity?
Here is the code I am using
using System.Collections;
using UnityEngine;
using FMODUnity;
using FMOD;
using System;
using FMOD.Studio;
public class ScriptUsageProgrammerSounds : MonoBehaviour
FMOD.Studio.EVENT_CALLBACK dialogueCallback;
public EventReference EventName;
private EventInstance eventInstance;
[Range(-100f, 100f)]
public float volumeParameter = 0f;
/* #if UNITY_EDITOR
    void Reset()
        EventName = EventReference.Find("event:/Character/Radio/Command");
#endif */
void Start()
    // Explicitly create the delegate object and assign it to a member so it doesn't get freed
    // by the garbage collected while it's being used
    dialogueCallback = new FMOD.Studio.EVENT_CALLBACK(DialogueEventCallback);
    PlayDialogue("reverb audio sample");
    eventInstance.setParameterByName("PAN_1", -100);
void PlayDialogue(string key)
    eventInstance = RuntimeManager.CreateInstance(EventName);
    // Pin the key string in memory and pass a pointer through the user data
    GCHandle stringHandle = GCHandle.Alloc(key);
    eventInstance.setUserData(GCHandle.ToIntPtr(stringHandle));
    eventInstance.setCallback(dialogueCallback);
    eventInstance.start();
    eventInstance.release();
static FMOD.RESULT DialogueEventCallback(FMOD.Studio.EVENT_CALLBACK_TYPE type, IntPtr instancePtr, IntPtr parameterPtr)
    FMOD.Studio.EventInstance instance = new FMOD.Studio.EventInstance(instancePtr);
    // Retrieve the user data
    IntPtr stringPtr;
    instance.getUserData(out stringPtr);
    // Get the string object
    GCHandle stringHandle = GCHandle.FromIntPtr(stringPtr);
    String key = stringHandle.Target as String;
    switch (type)
            FMOD.MODE soundMode = FMOD.MODE.LOOP_NORMAL | FMOD.MODE.CREATECOMPRESSEDSAMPLE | FMOD.MODE.NONBLOCKING;
            var parameter = (FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES)Marshal.PtrToStructure(parameterPtr, typeof(FMOD.Studio.PROGRAMMER_SOUND_PROPERTIES));
            if (key.Contains("."))
                FMOD.Sound dialogueSound;
                var soundResult = FMODUnity.RuntimeManager.CoreSystem.createSound(Application.streamingAssetsPath + "/" + key, soundMode, out dialogueSound);
                if (soundResult == FMOD.RESULT.OK)
                    parameter.sound = dialogueSound.handle;
                    parameter.subsoundIndex = -1;
                    Marshal.StructureToPtr(parameter, parameterPtr, false);
            else
                FMOD.Studio.SOUND_INFO dialogueSoundInfo;
                var keyResult = FMODUnity.RuntimeManager.StudioSystem.getSoundInfo(key, out dialogueSoundInfo);
                if (keyResult != FMOD.RESULT.OK)
                    break;
                var soundResult = FMODUnity.RuntimeManager.CoreSystem.createSound(dialogueSoundInfo.name_or_data, soundMode | dialogueSoundInfo.mode, ref dialogueSoundInfo.exinfo, out dialogueSound);
                    parameter.subsoundIndex = dialogueSoundInfo.subsoundindex;
            break;
        case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROY_PROGRAMMER_SOUND:
            var sound = new FMOD.Sound(parameter.sound);
            // sound.release();
            break;
        case FMOD.Studio.EVENT_CALLBACK_TYPE.DESTROYED:
            // Now the event has been destroyed, unpin the string memory so it can be garbage collected
            // stringHandle.Free();
            break;
    return FMOD.RESULT.OK;
void OnDestroy()
public void SetPan(float panValue)
    if (eventInstance.isValid())
        // Assuming a parameter named "Pan" is exposed in FMOD
        eventInstance.setParameterByName("Pan", Mathf.Clamp(panValue, -1f, 1f));
void Update()
    eventInstance.setParameterByName("PAN_1", volumeParameter);
Thank you for sharing the information and code.
Could you please provide some screenshots showing how the event is set up in FMOD Studio? Specifically:
  • What kind of effect you’re using (e.g. Reverb, Pan, EQ)
  • How you’ve automated the effect
  • The parameter settings you’ve created
This will help me better understand the setup and reproduce the issue on my end.
