That error occurs if you’re using a blueprint project with no project file - see the relevant section from the Troubleshooting chapter of our UE Docs for more info. The recommendation given in the thread you linked is still the solution.
Related topics
| Topic | Replies | Views | Activity | |
| Plugin 'FMODStudio' failed to load because module 'FMODStudio' could not be found | 15 | 5070 | March 12, 2024 | |
| Error when building for Windows from Unreal 5.3 with FMOD plugin | 5 | 3157 | February 3, 2025 | |
| FMODstudio for Unreal 5.2 not installing properly | 16 | 913 | November 22, 2023 | |
| Wondering whether there's a bug with the latest build of FMOD | 1 | 469 | February 17, 2023 | |
| Project requires the "FMODStudio Plugin" which could not be found. Need urgent help | 7 | 620 | March 21, 2024 |
