Cant store EventInstances in the list
Hi.
Im trying to store the EventInstance in the list after creation of the event , but error pops out NullReferenceException . I can start the event and it starts playing , but after i cant add it to the list.
Here is example of code:
            EventInstance audioEvent = CreateInstance(FMOD_Events.GetEventReference(audioName, FMOD_Events.Music));
            PlayLoop(audioEvent);
            eventInstances.Add(audioEvent);
What version of the FMOD Unity integration are you using?
Could I get the full script to test on my end?
I was able to add events to a list using the following code:
private List<FMOD.Studio.EventInstance> eventList = new List<FMOD.Studio.EventInstance> ();
void Start()
    eventList.Add(FMODUnity.RuntimeManager.CreateInstance($"event:/Music/Level 01"));
    eventList.Add(FMODUnity.RuntimeManager.CreateInstance($"event:/Music/Level 02"));
    for (int i = 0; i < eventList.Count; i++)
        eventList[i].start();
        eventList[i].release();
void Update()
    if (Input.GetKeyDown(KeyCode.Escape))
        for (int i = 0;i < eventList.Count;i++)
            eventList[i].stop(STOP_MODE.IMMEDIATE);
Hope this helps.
Wherever you have declared the list, make sure it is not null.
As Connor’s code has:
So the ... = new List<...>(); is the important part here, and not having it is probably causing the NullReferenceException.
