I am trying to use VST plugins for equalizing in a C# project. When I tried to follow the “dsp_effect_per_speaker” example, I alway get exceptions of the type “PInvokeStackImbalance” which seemingly have their origin in a non-matching PInvoke signature compared to the signature on the C++ side.
Here is a little example showing this:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace VST_Test
public partial class Form1 : Form
private FMOD.System fmod_system;
private FMOD.Sound sound_instance;
private FMOD.Channel fmod_channel;
private FMOD.ChannelGroup master_channelgroup;
private FMOD.DSP vst_plugin1, vst_plugin2;
private uint vst_plugin_handle;
private FMOD.DSP main_head, main_mixer;
private FMOD.DSPConnection dsp_left_out_connection, dsp_right_out_connection, dsp_left_in_connection, dsp_right_in_connection, main_mixer_connection;
private System.Windows.Forms.Form config_window;
public Form1()
InitializeComponent();
private void Form1_Shown(object sender, EventArgs e)
FMOD.Factory.System_Create(out fmod_system);
fmod_system.init(100, FMOD.INITFLAGS.NORMAL | FMOD.INITFLAGS.PROFILE_ENABLE | FMOD.INITFLAGS.PROFILE_METER_ALL, (IntPtr)0);
fmod_system.getMasterChannelGroup(out master_channelgroup);
fmod_system.loadPlugin("Nova67P.dll", out vst_plugin_handle);
fmod_system.createDSPByPlugin(vst_plugin_handle, out vst_plugin1);
fmod_system.createDSPByPlugin(vst_plugin_handle, out vst_plugin2);
fmod_system.createSound("Going-On.mp3", FMOD.MODE.NONBLOCKING, out sound_instance);
master_channelgroup.getDSP(FMOD.CHANNELCONTROL_DSP_INDEX.HEAD, out main_head);
main_head.getInput(0, out main_mixer, out main_mixer_connection);
//----------------------------------------------------- PROBLEM ------------------------------------------------
//main_head.disconnectFrom(main_mixer); // -------------------------- Causes PInvokeStackImbalance Exception
//vst_plugin1.addInput(main_head, out dsp_left_in_connection); // --- Same problem!
//main_head.addInput(vst_plugin1, out dsp_left_out_connection);// --- Same problem
master_channelgroup.addDSP(0, vst_plugin1); // ---------------------- Works!
private void button_play_Click(object sender, EventArgs e)
timer_update.Start();
fmod_system.playSound(sound_instance, master_channelgroup, false, out fmod_channel);
private void button_show_ui_Click(object sender, EventArgs e)
uint version;
int channels;
int config_width;
int config_height;
config_window = new Form();
config_window.Width = 763;
config_window.Height = 638;
config_window.Text = "Equalizer";
config_window.Show(this);
vst_plugin1.showConfigDialog(config_window.Handle, true);
private void timer_update_Tick(object sender, EventArgs e)
fmod_system.update();
Am I missing something or is this a bug in the C# wrapper?
Thanks for your help, Florian
