hi Mathew
i had use FMOD_INIT_VOL0_BECOMES_VIRTUAL in system init and allocate 0.01 to it.But when I use FMOD_Channel_setPriority make some channel priority to high, i see the channels always real channel though the audibility is 0,lower priority channel never chance stolen real channel.if i need a high priority be stolen by those with a lower priority when it in audibility is 0, what shall i do?
Firstly the priority system is a bucket list, i.e. all sounds in a lower priority grouping will go virtual before any in a higher grouping go virtual. The vol0 virtual flag will make any sound below your specified threshold go virtual regardless of priority unless the priority is set to 0 (highest), that special priority ensure a sound never goes virtual.
Thank you, Mathew. I got it.
