Checking the size of built banks
(spectralgeth) #1
Is there currently a way to do this in the most current version of Fmod? Sometimes I need to see specifics of how much data is being cached into memory with the size of a specific bank file, rather than the amount of memory being used at run-time, for instance.
(Cameron Baron) #2
The only way I can think of to do what you want, would be to use FMOD::Memory_GetStats before and after loading a bank to find out the current memory allocations.
https://fmod.com/resources/documentation-api?page=content/generated/FMOD_Memory_GetStats.html#/
