CLI run of FMod Studio not loading project while mac is locked
Hey there, am doing bank builds via CLI with the following command:
/Applications/FMOD Studio.app/Contents/MacOS/fmodstudio' -build FMod/<PROJECTNAME>.fspro and if the machine is locked (which it normally is while running jenkins) the project doesn’t complete loading.
I have a FMOD studio log (which I can’t yet attach), and there is a large time gap between the following lines:
- 2025-05-06 20:17:56 [Total Load FMod/<PROJECTNAME>.fspro 0x0000000142e7ffa0]: Time started
- 2025-05-06 20:31:20 [Opening FMod/<PROJECTNAME>.fspro 0x0000000142e7ffa0]: Time started
- 2025-05-06 20:31:20 [Create mappers]: Time started
(the project is extremely small, and the timestamps match up exactly with when I ran a remote desktop session and logged in)
In addition the jenkins logs for the bank build is as follows:
[2025-05-06T10:31:25.385Z] /opt/teamcity-agent/work/32de17c14a8f30d0/fsbank_api/src/fsbank_file_disk.cpp(26) : FSBank error (7) : An operating system based file error was encountered.
[2025-05-06T10:31:26.303Z] /opt/teamcity-agent/work/32de17c14a8f30d0/fsbank_api/src/fsbank_file_disk.cpp(26) : FSBank error (7) : An operating system based file error was encountered.
[2025-05-06T10:31:28.189Z] /opt/teamcity-agent/work/32de17c14a8f30d0/fsbank_api/src/fsbank_file_disk.cpp(26) : FSBank error (7) : An operating system based file error was encountered.
[2025-05-06T10:31:30.077Z] /opt/teamcity-agent/work/32de17c14a8f30d0/fsbank_api/src/fsbank_file_disk.cpp(26) : FSBank error (7) : An operating system based file error was encountered.
[2025-05-06T10:31:30.077Z] [ERR] ~Global                                  : assertion: 'gSystemInitCount == 0' failed
[2025-05-06T10:31:30.077Z] Loading project "FMod/K<PROJECTNAME>.fspro"...
[2025-05-06T10:31:30.077Z] Successfully opened project.
[2025-05-06T10:31:30.077Z] Building project "FMod/<PROJECTNAME>.fspro"...
[2025-05-06T10:31:30.077Z] Build Status: Gathering file stats...
[2025-05-06T10:31:30.077Z] Build Status: Preparing to build for Desktop...
[2025-05-06T10:31:30.078Z] Build Status: Checking dependencies for "Mother Tree - General"...
[2025-05-06T10:31:30.078Z] Build Status: Loading "<SCENE NAME> - General" objects...
[2025-05-06T10:31:30.078Z] Build Status: Building "<SCENE NAME> - General" for Desktop...
[2025-05-06T10:31:30.078Z] Build Status: Checking dependencies for "<SCENE NAME> - Music"...
[2025-05-06T10:31:30.078Z] Build Status: Loading "<SCENE NAME> - Music" objects...
[2025-05-06T10:31:30.078Z] Build Status: Building "<SCENE NAME> - Music" for Desktop...
[2025-05-06T10:31:30.078Z] Build Status: Checking dependencies for "Shared"...
[2025-05-06T10:31:30.078Z] Build Status: Loading "Shared" objects...
[2025-05-06T10:31:30.078Z] Build Status: Building "Shared" for Desktop...
[2025-05-06T10:31:30.078Z] Build Status: Preparing to build for WebGL...
[2025-05-06T10:31:30.078Z] Build Status: Checking dependencies for "<SCENE NAME> - General"...
[2025-05-06T10:31:30.078Z] Build Status: Building "<SCENE NAME> - General" for WebGL...
[2025-05-06T10:31:30.078Z] Build Status: Checking dependencies for "Mother Tree - Music"...
[2025-05-06T10:31:30.078Z] Build Status: Building "<SCENE NAME> - Music" for WebGL...
[2025-05-06T10:31:30.078Z] Build Status: Building "Shared" for WebGL...
[2025-05-06T10:31:30.078Z] Build completed successfully.
[Pipeline] }```
While I could check in the built banks and avoid this step, i'd rather not have derived files in the repo if I can avoid it!
Thank you for the information and the logs.
Using 2.02.29 and this build step:
echo "Build Studio Project"
'/Applications/FMOD Studio 2.02.25.app/Contents/MacOS/fmodstudio' -build '/Users/admin/Library/Application Support/FMOD Studio/2.02.25/Examples/Examples.fspro'
echo "Finished Building"
I was not able to reproduce the issue.
Could I please grab your FMOD versions and your build step?
I’m using fmod studio 2.03.07 build 150747 (macos)
So: it’s a problem with command line builds in general taking a long time.
In both cases i have removed the .cache, .user, .recycle and Build folders prior to building.
Using the GUI takes ~1 Minute from opening until build complete (see below)
GUIBuild.txt (55.8 KB)
Using the CLI the build takes 40 minutes to complete
CLIBuild.txt (40.1 KB)
(both of these were done on the same system)
Thank you for the information.
I have been able to reproduce the issue, I will pass it onto our development team to investigate further. Unfortunately I don’t have a workaround at this time.
Thank you for bringing this to our attention.
At least you can repro it! A solid repro is half the battle! :smiley:
ooof.. I just had this building for ~12 hours and it never finished - so in some cases it’s not just slow, it never finishes. I’ve attached the log
2025-05-07-18-04-48_log.txt (10.0 KB)
Thank you for the logs, I will add them to the task!
Is this addressed in 2.03.08 ? (I didn’t see anything obvious in the changelog)
Unfortunately, it is still in our back log. I will give it a bump
Hi, this is also impacting us, I wanted to add a bit more information.
The fmodstudio -build command hangs on mac even in a regular (non-headless) setup, until the FMOD dock icon is clicked.
This error is reported periodically while it’s hanging:
I was able to add a workaround to our build by running open -a "FMOD Studio" while FMOD is hanging; i.e., our build process now runs this before building banks:
Task.Run(async () =>
    await Task.Delay(1000);
    ProcessExtensions.Run("open", "-a \"FMOD Studio\"");
I wonder if i can somehow trigger that from Jenkins build scripts (even if we’re not logged in…)
I really need a solve for this, because it’s actively blocking us from using FMod in our main game
Thank you for sharing, I will add the information to the task.
Another small update after running this on the build servers for a week: we found that sometimes a second instance of FMOD was running, and stuck on the welcome screen. This prevented the open -atrick from working, as it was activating the wrong process. I’m not sure where this second FMOD instance is being started from, but we worked around the issue by running a killall fmodstudio before running the batch process.
With these two workarounds we have reliable FMOD batch builds running on our mac CI now. FMOD engineers should be able to fix the issue more robustly for everyone by either running the batch process before entering the GUI loop (i.e., in main() instead of NSApplicationDelegate), or building a separate console-only target to host the batch builds.
Thank you for the information. I will update the forum when there is progress on the task.
Just wondering where this is at - it’s been about 6 months since it was reported, and nearly 4 since any updates happened?
Fix is in development and is in the pipe for first release of the new year.
Just wondering where this is at?
Very close. Hopefully out in a week or two.
I just noticed that fmodstudiocl exists in the mac package as of 2.03.13 and decided to try that. Inside a jenkins build it doesn’t work, generating the following errors:
'/Applications/FMOD Studio.app/Contents/MacOS/fmodstudiocl' -build <PROJECT>/<PROJECT>.fspro
14:48:35  The files /Users/<USER>/jenkins-windows/workspace/<PROJECT>-Debug/a, /Users/darkdarkgoose/jenkins-windows/workspace/<PROJECT>-Debug/tty, /Users/<USER>/jenkins-windows/workspace/<PROJECT>-Debug/a, and /Users/<USER>/jenkins-windows/workspace/<PROJECT>-Debug/tty do not exist.
I’m not sure why it’d need to access those non-existant files. I can increase the verbosity (alternately maybe fmodstudiocl isn’t working on macOS yet?)
Thanks for the report. Looking into it here.
