We’re using an internal dialogue system in our games that supports localization (languages). The dialogue assets are provided as .wav files in a language specific folder, and we use the FMOD command line API to compile/encode the wavs to the platform specific format.
Earlier on it turned out that the compiler cannot handle 24 bit wavs, so we had to make them all 16 bit. Now it’s also turned out that if there’s a BWF metadata chunk in the wav file, the compiler may refuse the file with an error. I need to strip the BWF chunks from the wavs to make them compile.
Is there something in the FMOD command line API that would have problems with this or should we take a closer look at our own compiler?
FMOD Studio itself can import 24-bit wavs with BWF chunks just fine.
