I’ve had a major issue with fmod studio 2.02.22-20.02.26 on Ubuntu 24.04.1 where trying to build banks suddenly crashes fmod.
I managed to fix it once by completely removing fmod from my system, including all remaining folders I could find and by reinstalling. However I’m having the same issue again and I can’t fix it again.
The exact same project synchronized via git with git-lfs builds fine on other computers (Ubuntu 24.04.1, Windows). I did find however that trying to compress some ogg files also crashes fmod so that may be the issue?
Does FMOD Studio display the crash report dialog when crashing? If so, could you use it to report the crash using the same name and email address you use for the forums?
Can I get you to post a log from Studio where the issue occurs? You should be able to find the log at ~home/FMOD Studio/Logs
I got more info by running FMOD Studio from the terminal:
Warning: Ignoring XDG_SESSION_TYPE=wayland on Gnome. Use QT_QPA_PLATFORM=wayland to run on Wayland anyway.
[Initialize Sound System 0x000000003981bb50]: Time started
[Initialize Sound System 0x000000003981bb50]: Time taken is 39.98ms (0.039s)
[Total Load Geofictions.fspro 0x00000000398063c0]: Time started
[Opening Geofictions.fspro 0x00000000398063c0]: Time started
[Create mappers]: Time started
[Create mappers]: Time taken is 4.33ms (0.004s)
[Total preload]: Time started
[Preload mappers]: Time started
The file /home/gael/code/art/geofictions/geofiction-proto01-unity/FMODStudio/Geofictions/Metadata/ParameterPreset/{1143f626-1092-43ec-86fd-42b3174b2280}.xml is either corrupted or not an FMOD Studio file.
Objects loaded: 599
[Object Decoder]: Total time is 86.96ms (0.086s)
[I/O Bound]: Total time is 4.78ms (0.004s)
[Preload mappers]: Time taken is 92.75ms (0.092s)
[Hookup relationships]: Time started
[Hookup relationships]: Time taken is 28.81ms (0.028s)
[Sort relationships]: Time started
[Sort relationships]: Time taken is 17.06ms (0.017s)
[Finalize loading]: Time started
[Uninitialize Sound System 0x000000003981bb50]: Time started
[Uninitialize Sound System 0x000000003981bb50]: Time taken is 21.95ms (0.021s)
[Initialize Sound System 0x000000003981bb50]: Time taken is 50.25ms (0.050s)
[Finalize loading]: Time taken is 127.60ms (0.127s)
[Total preload]: Time taken is 267.07ms (0.267s)
[Resync auditioning Geofictions.fspro 0x00000000398063c0]: Time started
[Resync Auditioning Queue 0x000000003981bb50]: Time started
Resyncing (build: 147, delete: 0, mute: 0)
[Resync Auditioning Queue 0x000000003981bb50]: Time taken is 21.91ms (0.021s)
[Resync auditioning Geofictions.fspro 0x00000000398063c0]: Time taken is 22.19ms (0.022s)
[Opening Geofictions.fspro 0x00000000398063c0]: Time taken is 304.08ms (0.304s)
[Total Load Geofictions.fspro 0x00000000398063c0]: Time taken is 337.58ms (0.337s)
ScriptServer started on 0.0.0.0 (3663)
QWidget::setWindowModified: The window title does not contain a '[*]' placeholder
[Build 6 banks for 1 platforms]: Time started
[Gather file stats in /home/gael/code/art/geofictions/geofiction-proto01-unity/FMODStudio/Geofictions/Assets]: Time started
[Gather file stats in /home/gael/code/art/geofictions/geofiction-proto01-unity/FMODStudio/Geofictions/Assets]: Time taken is 4.34ms (0.004s)
[Dynamic load]: Time started
Objects loaded: 549
[Finalize loading]: Time taken is 42.14ms (0.042s)
[Object Decoder]: Total time is 28.12ms (0.028s)
[I/O Bound]: Total time is 1.13ms (0.001s)
[Dynamic load]: Time taken is 101.49ms (0.101s)
[Build bank "Ambiences"]: Time started
[Write /home/gael/code/art/geofictions/geofiction-proto01-unity/FMODStudio/Geofictions/Build/Desktop/Ambiences.bank to file]: Time started
../../src/fsbank_file_disk.cpp(45) : FSBank error (7) : An operating system based file error was encountered.
fmod_output_pulseaudio.cpp(181), PulseAudio_StreamUnderflowCallback(): Buffer underrun detected in PulseAudio. Current block Count = 4
fmod_output_pulseaudio.cpp(181), PulseAudio_StreamUnderflowCallback(): Buffer underrun detected in PulseAudio. Current block Count = 5
Killed
I suspect the issue is being caused by corrupted files, like you suggested, but it’s difficult to diagnose from just the logs. Could I get you to upload your Studio project, making sure you include all the assets assigned to the ambience bank, to the uploads section your FMOD User Profile for me to take a closer look at?
It’s also possible that source control may be interfering with files on disk in some way, e.g. locking files that are being written to, or writing to files/directories that should be excluded. Have the directories/files noted in our documentation on using source control with Studio been excluded/ignored?
In case that’s any help, I tried to repair the ogg files from the ambience folders as well as replacing them with wav or mp3 with no success.
We’re using git with git-lfs as version control, the FMOD Studio directory is at the root of or repo next to the unity project. The directories noted in documentation should have been excluded I think, although I initially forgot .cache, .user and .unsaved.
I included our gitignore to the upload so you can check for yourself.
After a bunch of testing on my end, I unfortunately haven’t been able to reproduce the issue you’re experiencing. The corrupt metadata file is benign, as it’s not being referenced anywhere else in the project, but it does point to there likely being some issue with how git-lfs is interacting with the local copy of the Studio project’s files.
Besides doing a completely fresh pull of the remote copy, I’d recommend doing the following and seeing whether they make any difference:
Ensure no files or directories are being erroneously locked by git, or have any weirdness with their R/W permissions, especially on existing built banks, assets, or the .cache directory
Completely delete any existing banks and try rebuilding them
Relocate the built bank and/or asset directories from where they’re currently located (in Edit → Preferences → Build/Assets respectively)
Relocate the entire Studio project
As an aside, I don’t seem to have your gitignore in the project upload, so if you could provide it or the relevant parts of it here, that’d be great.
Thank you for your suggestions, I tried it all suggestions but none of it worked.
I checked all assets files with lsof in case some were locked but it looks fine.
It turns out, I get the same issue when building banks from the fmod example project.
[Initialize Sound System 0x0000000028fe7a20]: Time started
[Initialize Sound System 0x0000000028fe7a20]: Time taken is 16.50ms (0.016s)
[Uninitialize Sound System 0x0000000028fe7a20]: Time started
[Uninitialize Sound System 0x0000000028fe7a20]: Time taken is 48.75ms (0.048s)
[Initialize Sound System 0x0000000028fe7a20]: Time taken is 35.79ms (0.035s)
[Initialize Sound System 0x0000000029f9e4c0]: Time started
[Initialize Sound System 0x0000000029f9e4c0]: Time taken is 17.96ms (0.017s)
[Total Load /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time started
[Opening /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time started
[Create mappers]: Time taken is 0.95ms (0.000s)
Objects loaded: 680
[Object Decoder]: Total time is 13.83ms (0.013s)
[I/O Bound]: Total time is 6.05ms (0.006s)
[Preload mappers]: Time taken is 20.11ms (0.020s)
[Hookup relationships]: Time taken is 19.65ms (0.019s)
[Sort relationships]: Time taken is 4.01ms (0.004s)
[Uninitialize Sound System 0x0000000029f9e4c0]: Time started
[Uninitialize Sound System 0x0000000029f9e4c0]: Time taken is 8.65ms (0.008s)
[Initialize Sound System 0x0000000029f9e4c0]: Time taken is 14.48ms (0.014s)
[Finalize loading]: Time taken is 38.47ms (0.038s)
[Total preload]: Time taken is 82.48ms (0.082s)
[Resync auditioning /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time started
[Resync Auditioning Queue 0x0000000029f9e4c0]: Time started
Resyncing (build: 109, delete: 0, mute: 0)
[Resync Auditioning Queue 0x0000000029f9e4c0]: Time taken is 7.75ms (0.007s)
[Resync auditioning /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time taken is 7.81ms (0.007s)
[Opening /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time taken is 94.78ms (0.094s)
[Total Load /home/gael/.local/share/fmod-studio/2.02.26/examples/Examples.fspro 0x0000000029f4fbe0]: Time taken is 99.24ms (0.099s)
[Obliterate workspace]: Time started
[Obliterate workspace]: Time taken is 0.54ms (0.000s)
[Uninitialize Sound System 0x0000000028fe7a20]: Time taken is 24.19ms (0.024s)
[Gather file stats in /home/gael/.local/share/fmod-studio/2.02.26/examples/Assets]: Time started
[Gather file stats in /home/gael/.local/share/fmod-studio/2.02.26/examples/Assets]: Time taken is 3.20ms (0.003s)
Objects loaded: 351
[Finalize loading]: Time taken is 9.46ms (0.009s)
[Object Decoder]: Total time is 15.12ms (0.015s)
[I/O Bound]: Total time is 0.92ms (0.000s)
[Dynamic load]: Time taken is 34.14ms (0.034s)
[Build bank "Music"]: Time started
[Write /home/gael/.local/share/fmod-studio/2.02.26/examples/Build/Desktop/Music.bank to file]: Time started
../../src/fsbank_file_disk.cpp(26) : FSBank error (7) : An operating system based file error was encountered.
Killed
Edit: I upgraded to Ubuntu 24.10, the problem is still there
Given that none of my previous suggestions appeared to resolve the issue, it’s worth testing the lower-level functionality behind the bank building process to see whether the issue reproduces outside of Studio.
The problem line of code appears to just be making a call into fread from stdio.h, so could I get you to compile and run the following code from the “Reading from a Binary File” example from this page and see whether you run into any issues?
// C Program to Read from a
// binary file using fread()
#include <stdio.h>
#include <stdlib.h>
struct Num
int n1, n2;
// Driver code
int main()
int n;
struct Num obj;
FILE* fptr;
if ((fptr = fopen("temp.bin", "rb")) == NULL)
printf("Error! opening file");
// If file pointer will return NULL
// Program will exit.
exit(1);
// else it will return a pointer
// to the file.
for (n = 1; n < 10; ++n)
fread(&obj, sizeof(struct Num), 1, fptr);
printf("n1: %d\tn2: %d\n", obj.n1, obj.n2);
fclose(fptr);
return 0;
Thanks for testing - that likely rules out any dependency problems.
A few followup questions:
Was the FMOD Studio example project you were able to reproduce the issue with also checked into git?
You mentioned that the issue is present on 2.02.22 to 2.02.26 - does the issue not occur on 2.02.21? If it still does, can I get you to test which prior version of Studio, if any, it doesn’t occur in?
Can I get you to try building an FSB with some audio files using the standalone FMOD Soundbank Generator tool and see whether you run into any errors? The tool is the “fsbank” executable in the “bin” directory of the FMOD Engine installer
I tried a few older 2.02 version as well as 23.03 with no success. I did not update fmod when the build stopped working, it just happened suddenly
The FSB also crashes with the same error, here’s the log:
qt.qpa.plugin: Could not find the Qt platform plugin "wayland" in ""
Killed
Thanks for getting back to me, and apologies for the delay on my end as well.
Given the consistency of the crash, there’s not much else I can get you to try right now. However, I’m going to see about creating a debug build of the FMOD Soundbank Generator tool with some extra logging for you to test, which should hopefully help track down the exact problem. I’ll get back to you with it soon!
Thank you, also do you have a list of the paths where FMOD Studio installs to as well as configs/storage…
I’d like to make sure I can properly remove FMOD Studio before reinstalling it, just in case.
Sorry again for the delay - a custom build of the fsbank command line executable has been uploaded to the uploads section of your FMOD User profile. Please give using it a try with a command like the following:
and post the log here. If manually providing files to the command line as input is tedious, you can use the regular FMOD Soundbank Generator GUI tool to select a number of files and save them as a .fsproj file, and use that as the input for the command line instead.
As for Studio’s directories, for 2.02 they should be as follows:
I tried it with single wav files and it worked properly, however it failed for all ogg files I tried and most mp3 files but not all…
The log is the same everytime it fails, here is one of them:
Gathering files...
Analysing files...
Processing args...
Compiling soundbank testBank_ogg.fsb
Build started
readFile(): Issue with fread, return value is 0
readFile(): EOF reached
0: (Master.ogg) [processing]
Killed
I exported multiple files from ardour using the same session and same export settings. I changed the length of the export from one file to another. I found that:
if the file exceeds a certain length fsbank will crash
if I add multiple files slightly under this limit, fsbank does not crash.
there’s a certain file length range where fsbank can build once and then crashes on rebuild
the file length limit is not the same if I export an mp3 or ogg file
the file size limit is not the same for mp3 and ogg files
I uploaded a zip on my profile with some of the test files I used
Edit: just in case, I opened and read the beginning of the crashing files with fread without any issue
Could I get you to double check that those files have been uploaded to your profile? There currently only appears to be a single file attached to your profile, which is the custom FSBank build. Also, can you please to upload the complete log(s) from when you run FSBank alongside those test files?
Sorry I think I made a mistake while uploading, it should be fine now. The log I sent you is the complete log I get from the fsbank build. I redirected the stderr and stdout too and did not get any more log.
I downloaded the latest version of fmodstudio (2.03.07) as appimage and it works!
The deb version crashes on opening long audio files whenever I compiled the project once.
Happy to hear that the appimage resolved the issue for you! The fact that the appimage works as expected points at some kind of esoteric dependency issue, since the appimage comes with all its dependencies, while the deb does not.
