Crash in mixerSuspend
We encountered an Android ARM64 crash inside the FMOD mixer thread while calling System::mixerSuspend(). The complete FMOD logging-library output is available and will be attached.
Environment:
  • FMOD Engine: 2.03.14
  • FMOD library: libfmodL.so, ARM64
  • Device: Samsung SM-A715F
  • OS: Android 12 / SDK 31
  • Application build: 26.5.0.42912
  • FMOD output: AAudio
  • Output configuration: default output, 48 kHz, stereo
  • Local libfmodL.so build ID: 7f6812d87ea9d1a9ea3369c789434094
Crash summary:
Thread: FMOD mixer thre
Signal: 11 (Segmentation fault)
Fault address: 0x0000000000000000
0 libc.so sem_post
1 libfmodL.so 0x140f90
2 libfmodL.so 0x140f90
3 libfmodL.so 0x1381a8
4 libfmodL.so 0x1409d8
5 libc.so
6 libc.so
The crash happened during:
DeviceManagerPollEvents
→ Pause
→ FMODAudioManager
→ FMOD_System_MixerSuspend
Relevant sequence from the log:
  1. FMOD successfully initialized with AAudio:
20:56:06.615
FMOD output after initialization:
type=AAudio (18), drivers=4, selected driver=0 ‘(Default Output)’,
rate=48000 Hz, speaker mode=3, channels=2
  1. The application completed two earlier mixer suspend/resume cycles successfully. Each cycle logged:
FMOD mixer suspend requested
SystemI::mixerSuspend: Suspending output.
Thread::callback: FMOD mixer thread finished.
FMOD mixer suspend completed
FMOD mixer resume requested
Thread::initThread: Init FMOD mixer thread.
FMOD mixer resume completed
  1. Microphone capture was subsequently opened:
20:56:54.272
MicrophoneController: Starting audio capture at 44100 Hz
20:56:54.548
AudioManager: Opened audio capture device with sample rate 44100,
frames 2048, channels 1.
  1. Approximately one minute later, while the application was active and not paused, FMOD failed to stop an AAudio stream:
20:57:53.727
fmod_output_aaudio.cpp:201 AAudio_StopStreamBlocking
Failed to stop stream after 1000ms. State = 13. Result = -885.
20:57:53.728
fmod_output_aaudio.cpp:1010 AAudio_Stop
Cannot stop stream. Result = 0xFFFFFC8B.
At this point the diagnostic context reported:
Paused:false
StackInfo:/Update/GameAudioManager
We understand state 13 to be AAUDIO_STREAM_STATE_DISCONNECTED and result -885 to be AAUDIO_ERROR_TIMEOUT.
  1. FMOD then automatically reconstructed the output:
20:57:54.202
AAudio_CreateOutputStream:
Could not set driver at index [0]. Defaulting to driver with id: 3.
20:57:54.202
AAudio_Init:
Sample rate: HW = 48000, SW = 24000
Block size: HW = 192, SW = 512.
20:57:54.207
Thread::initThread:
Init FMOD mixer thread. Semaphore: Yes, Looping: Yes.
20:57:54.209
Thread::callback:
Before this reinitialization, the hardware block size was 96 rather than 192.
  1. About five seconds later, the application was paused because the user started an Android in-app purchase:
20:57:58.934
StartBuying(com.outfit7.xxx.soc_bundle)
20:57:58.954
Extern call: Pause
The application first closed its microphone capture device and then suspended FMOD:
20:57:58.968
MicrophoneController: Stopping audio capture
20:57:58.968
AudioManager: Closing audio capture device
20:57:59.043
FMOD pause callback: initialized=1, mixer suspended=0
20:57:59.044
FMOD mixer suspend requested: suspended before=0
20:57:59.044
Suspending output.
20:57:59.046
Thread::callback:
20:57:59.055
CRASH: FMOD mixer thread, SIGSEGV, fault address 0x0
The FMOD mixer suspend completed message was never reached.
We inspected the bundled ARM64 binary around the crash offsets. The sequence corresponding to the stack is:
0x1381a0 Load a semaphore pointer from the FMOD thread object
0x1381a4 Call FMOD’s semaphore-post wrapper
0x140f8c Call libc sem_post
0x140f90 Return address reported in the crash
0x1381a8 Caller return address reported in the crash
0x1409d8 FMOD OS thread trampoline after the thread callback
This appears to indicate that the mixer thread logged that it had finished and then attempted to post a null or already-cleared internal completion semaphore.
Integration details:
  • mixerSuspend() and mixerResume() are called from the same main/lifecycle thread.
  • Duplicate suspend/resume requests are guarded.
  • FMOD Studio updates are skipped while the mixer is suspended.
  • During the fatal transition, an asynchronous UI sound load completed before the pause handler called mixerSuspend().
  • We do not see another project-initiated FMOD API call after the final mixerSuspend() begins.
  • Earlier suspend/resume cycles in the same session completed successfully.
  • The crash only occurred after the AAudio stop timeout and automatic output/mixer-thread reconstruction.
Thank you for the detailed write up. I can reproduce the Failed to stop stream error by disconnecting headphones during a suspend, but I haven’t reproduced a segfault yet.
If you have the full log available, can you please upload it to your FMOD Profile?
its up
any info on this?
Sorry for the delay, I’ve got a hypothetical reproduction of this issue- the problem is with a recent change that was supposed to solve a similar deadlock, but now means the mixer thread won’t close if an error is encountered during mixerSuspend, resulting in the mixer thread calling into a freed semaphore.
I’ll write this up for the dev team to fix in a future release, thank you for reporting this issue.
The only workaround for the time being would be to pause/unpause the master bus during background/foreground transitions instead of suspending/resuming the mixer. i.e
FMOD::Studio::Bus* masterBus;
system->getBus("bus:/", &masterBus);
FMOD::ChannelGroup* masterChannelGroup;
masterBus->getChannelGroup(&masterChannelGroup);
//Suspend
masterChannelGroup->setPaused(true);
//Reume
masterChannelGroup->setPaused(false);
ok, we’ll see how critical it is when we go live. any timeline on the fix?
We are close to the end of our current release window, so it has been scheduled for the release after that, likely in a month’s time.
I can however get you a non-QA approved build once the fix becomes available.
Yeah, that would be nice :slight_smile:
Thanks
If I read correctly, current android impl of mixerSuspend/Resume shuts down audio device?
Yes as of 2.03.06 mixerSuspend shuts down the audio device on Android. This was to prevent an audio glitch:
  • Core API - Android - Fixed small amount of old audio being played after calling System::mixerResume when using OpenSL or AAudio output types.
We are also having some issues on android with native os video recorders. On some samsung device we see long freezes when video recording is started, while on some pixel devices, recorder does not “collect” audio - the video is silent during playback. Need to try with mainbus pause/resume…
We’re hitting what looks like the same issue in production, also on 2.03.14 (release libfmod.so, build 164239, arm64-v8a, Studio API, default output selection, AAudio, from System::getOutput). Some data in case it helps confirm the fix:
  • 49 native crashes from 28 users since July, on Android 13 to 17 only, across Samsung (Snapdragon and Exynos), Motorola (MediaTek), Pixel 6a and 8 Pro, vivo, Xiaomi, OnePlus, and OPPO. SIGSEGV in bionic sem_post with stripped callers. It started with our upgrade from 2.02.28 to 2.03.14.
  • On backgrounding we call Studio::System::flushCommands() twice, then System::mixerSuspend() on the UI thread. No other thread of ours is inside FMOD at that point: we block entry and drain in-flight calls first. In every crash we have breadcrumbs for, the crash comes 2 to 120 ms after mixerSuspend is entered. In most of them, mixerSuspend still returns FMOD_OK 15 to 30 ms after the fault. That fits the mixer thread crashing on its own while the caller carries on.
  • We also saw the same crash before we called mixerSuspend at all. For about three weeks in July, our backgrounding handler only muted the master channel group. Those builds still produced 20 of the 49 crashes: most at the moment the activity stopped, and one a few minutes into the background. Could the automatic output rebuild after an AAudio disconnect reach the same freed-semaphore path? If so, the master-bus pause workaround may not cover everything.
Is there a release with the fix yet, or could we also try the pre-release build you mentioned? We’d be happy to test it.
Thank you for the additional insights. Muting the master channel group shouldn’t dismantle the output, as mixerSuspend does, but while investigating this I did find a race condition where a crash can sometimes occur if a device is connected, and then disconnected while the new device is starting. This might explain the July crashed that didn’t involve mixerSuspend.
I’ve uploaded a non-QA-approved build containing this fix to your FMOD profile, and it would be great to hear if you can still reproduce any of these issues.
We recommend never shipping with non-QA-approved approved builds, so please ensure you update to 2.03.16 when it becomes available.
Hey Jeff.
Does 2.04.00 have the same issue with device connect/disconnect? If so, will version 2.04 receive the same fix in 2.04.01?
Yes 2.04 will have the same issue, and it will be fixed in 2.04.01.
Hi Jeff
We are investigating an Android crash with the following setup.
  • Unreal Engine 4.27.2
  • FMOD Unreal Integration 2.03.06
  • Android ARM64, Shipping build, AAudio output
  • Latest reproduction on Sony A402SO running Android 14
The crash occurs during a startup pause/resume sequence involving the Android permission dialog. Our integration dispatches both mixerSuspend() and mixerResume() calls to the Unreal GameThread.
ART reports:
JNI DETECTED ERROR IN APPLICATION: java_array == null
in call to GetArrayLength
The relevant stack is:
libfmod.so + 0x11e2fc
libfmod.so + 0x13ef78
FMOD::System::mixerResume() + 208
FFMODStudioModule::SetSystemPaused(bool) + 172
TGraphTask::ExecuteTask(…)
libfmod.so Build ID is 32ed8c8c6b0dc443cc2ca6e35ccbcdd1.
For completeness, an application SDK logged an ArrayIndexOutOfBoundsException on the same GameThread about 896 ms earlier. The SDK implementation we inspected catches Throwable, logs the exception and returns normally, and the log contains the handler’s completion marker. We have not established a connection between that handled exception and the FMOD crash.
Could this crash be related to the output-device lifecycle race discussed in this thread, particularly reply #13? Our failure is a SIGABRT from GetArrayLength(null), whereas that discussion reports SIGSEGV in sem_post.
Could you help confirm whether this indicates an issue within FMOD’s resume/device-enumeration path, or whether an application-side JNI or integration issue could produce this stack? Please let us know which additional diagnostics or FMOD version would help distinguish these possibilities.
I don’t think that this would be related to the race I mentioned- 2.03.06 only has one jni call to GetArrayLength and that is during audio device enumeration, which is unrelated to the race.
The only situation I can think of where GetArrayLength would be called on a null object in this case is if the audio service isn’t yet available after switching the application back in.
Is there anything in the log to suggest the audio manager might be unavailable?
And is this an issue you are able to reproduce locally or is this showing up in your telemetry?
If you could please upload the log to your FMOD Profile I’ll see if there are any other clues.
Thanks for clarifying that this is separate from the device connection/disconnection race.
Regarding AudioManager availability, we have not found direct evidence that Android’s AudioManager or audio service was unavailable at the time of the crash. There was an earlier audio-stream creation failure, but a subsequent stream started successfully, so temporary unavailability during resume remains unconfirmed.
We can reproduce the crash locally on a test device. It is not limited to telemetry reports. The captured case is on a Sony A402SO running Android 14, using UE 4.27.2 and FMOD 2.03.06.
I have uploaded both the Android logcat and the UE application log to our FMOD Profile for your review.
Please let us know if any additional instrumentation would help confirm the audio-service availability at the failing enumeration call.
Thanks for your support and the time you spent investigating this.
We traced the issue to an unhandled Java error during initialization of one of our SDKs. After fixing that issue, we restored the Android mixerSuspend() and mixerResume() calls and verified that the crash no longer occurs.
It took us some time to obtain and test the build with the mixer suspend/resume logic temporarily disabled. That test helped expose the SDK error. With validation now complete, we have confirmed that the issue was in our SDK integration and that the FMOD plugin is working correctly.
Thank you again for your patience and help in tracking this down.
