I just started Android and fmod development.
I have fmod initializing and playing sounds fine on a Windows7 platform.
On Android, I’ve created a simple test where I have an Java app calling out to my own *.so (jni) lib that I’ve created. (I’m compiling using the Android API level 14).
So far things work fine.
My jni *so lib then goes on to initialize fmod and it crashes inside the FMod::Studio::System::initialize() call.
I’m running my test on the Android Emulator:
CPU/ABI: ARM (Armabi-v7a)
Target: Android 4.4 (API Level 19)
RAM: 343
VM Heap: 32
Skin: 480x800
hm.dPad: no
hw.lcd.density: 240
avd.ini.encoding: ISO-8859-1
hw.device.hash: 499058361
hx.camera.back: none
disk.dataPartition.size: 200M
hw.gpu.enabled: yes
skin.dynamic: yes
Using the debug fmod and studio libs, my LogCat output is:
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::init : FMOD Studio Version: 00010300 (51513)
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::init : maxchannels = 1, flags = 00000004, extradriverdata = 0x0
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::close :
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::close : Stop all sounds
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::close : Remove miscllaneous DSP stuff.
03-14 16:42:30.431: I/fmod(1369): FMOD: SystemI::close : done.
03-14 16:42:30.441: I/fmod(1369): FMOD: FMOD_OS_Init : Detected Neon instruction support, will use Neon optimized mixing and resampling.
03-14 16:42:30.441: I/fmod(1369): FMOD: SystemI::init : Set up software engine
03-14 16:42:30.451: I/fmod(1369): FMOD: OutputOpenSL::init : Initializing…
03-14 16:42:30.451: I/fmod(1369): FMOD: OutputOpenSL::init : Only mono and stereo supported, defaulting to stereo.
03-14 16:42:30.461: I/fmod(1369): FMOD: OutputOpenSL::init : Done.
03-14 16:42:30.471: I/fmod(1369): FMOD: OutputOpenSL::start : Starting…
03-14 16:42:30.481: I/fmod(1369): FMOD: OutputOpenSL::start : Done.
03-14 16:42:30.481: I/fmod(1369): FMOD: OutputPolled::start : Starting thread that automatically wakes up every 10 ms
03-14 16:42:30.481: I/fmod(1369): FMOD: Thread::initThread : Initializing FMOD mixer thread. priority 3
03-14 16:42:30.481: I/fmod(1369): FMOD: Thread::initThread : - Stacksize 49152. Stack pointer 0x0 : usesemaphore = 0 : sleeptime = 10
[color=#FF0000]03-14 16:42:30.481: A/libc(1369): Fatal signal 11 (SIGSEGV) at 0x00000000 (code=1), thread 1383 (hmx.test)
[/color]
My fmod initialization code is simple:
// init fmod system for low-level api
void* extradriverdata = nullptr;
// Create a System object and initialize.
FMOD_FAIL( FMOD::Studio::System::create(&mSystem) );
FMOD_STUDIO_INITFLAGS studioFlags = FMOD_INIT_NORMAL;
FMOD_STUDIO_INITFLAGS lowLevelFlags = FMOD_INIT_NORMAL|FMOD_INIT_3D_RIGHTHANDED;
// init!
FMOD_FAIL( mSystem->initialize(1, studioFlags, lowLevelFlags, extradriverdata) ); // << CRASH on android
FMOD_FAIL( mSystem->getLowLevelSystem(&mLowLevelSystem) );
Ha sanybody else gotten this problem?
Any help on this would be greatly appreciated!
xris
