Dears,
I write a test program that call fmod api, but compile it to binary file. I push the binary file to android device, but it always fails in fmod->init() line. The error code is 28. Do you know why it fails? The attached file is my sample code, thanks.
/* the below is my code */
#include <fmod.hpp>
#include <stdio.h>
#include <unistd.h>
int main(void)
    printf("1\n");
    FMOD::System     *system;
    FMOD::Sound      *sound1, *sound2, *sound3;
    FMOD::Channel    *channel = 0;
    FMOD_RESULT       result;
    unsigned int      version;
    void             *extradriverdata = 0;
    result = FMOD::System_Create(&system);
    printf("%d System_Create\n", result);
    result = system->getVersion(&version);
    printf("%d getVersion\n", result);
    if (version < FMOD_VERSION)
        //Common_Fatal("FMOD lib version %08x doesn't match header version %08x", version, FMOD_VERSION);
        return 1;
    result = system->init(32, FMOD_INIT_NORMAL, extradriverdata);
    if(FMOD_OK != result)
        printf("init error1\n");
        return 1;
    result = sound1->setMode(FMOD_LOOP_OFF);    /* drumloop.wav has embedded loop points which automatically makes looping turn on, */
    printf("%dsetmode\n", result);
    result = system->createSound("jaguar.wav", FMOD_DEFAULT, 0, &sound2);
    printf("%dreateSound\n", result);
    result = system->playSound(sound2, 0, false, &channel);
    printf("%dplaySound\n", result);
    do
        bool         playing = 0;
        result = channel->isPlaying(&playing);
        printf("%dsPlaying:%d\n", result, playing);
        sleep(50);
    }while(true);
    return 0;
