Drag and drop multiple assets to timeline sequentially
Currently if i select a bunch of assets, and drag it to the timeline, it automatically creates a Multi instrument. Which is fine if you want to do that.
But i’m building up songs with separated elements like
Drums (intro, verse, chorus, bridge)
Bass (intro, verse, chorus, bridge)
etc.
And it’s incredibly tedious to drag all the assets one by one to the timeline.
Is there an option to put dropped assets sequentially onto the timeline? That would help a LOT!
Like in Reaper when you drag multiple files to the timeline, it asks you how would you like to drop them. Sequentialy, or to create a new track for each asset.
A toggle option for this in the options should be fine
Thanks,
Matt
If you drag a multiselection of asset onto the events browser, you’ll be given the option of creating an event where each asset is on a different track, but there’s currently no way to automatically spread a dragged multiselection of assets out along the timeline.
I can see how it would be useful, though, so I’ll add your suggestion to our feature/improvement tracker.
I should mention that you can make a multi instrument to play a series of assets in sequence by setting its playlist selection mode to “sequential - local” and setting its play count to the number of entries in its playlist. This method is incompatible with certain forms of timeline logic and other event content, but is an easy way of achieving the behavior in many common cases.
Hi there @joseph . Just to say that this feature is a must have IMO. I think it’s the operation for which I lose the most time. Thanks!
Agree so much with this feature. Even having an shift/alt/ctrl modifier to change what dragging a group of audio clips in would save so much time. In Adobe Audition it does exactly this, or, in Reaper once you let go of the dragged in items it asks what you would like to do, sequential or separate tracks… I understand the idea of having it as a multi being able to play sequentially but sometimes its necessary to drag sequentially, and sometimes I’ve got upwards to 30 sequential tracks to drag in manually.
Thanks for the feedback! I’ve added you to the list of people interested in this feature.
LineupAssetsOnTrack.txt (4.8 KB)
Bit late to the party but I got tired enough of having to manually do this that I made a script for it. Change this text file to a .js and place it in your scripts folder. Then select assets, select target track, and it’ll spot them to that track sequentially at the location of playback cursor (in the same order as in the browser). Added bonus is if you do it to a parameter sheet it’ll space them out evenly across the parameter range.
Thanks Ed!
Will have to try it out and will let you know.
